CSS11506 - Getting there but still a bit more help
dclee
Currently terminating SSL connection on CSS with backend webserver connected to isolated vlan off CSS module. This now seems to be working well. However my next step is I have a need to move the backend server off the CSS completely and back into our production LAN. I have been told I dont need to have my server connected to the CSS. Here is my config. Can someone have a look at it and let me know what do I need to do in order to make this move happen ?
CSS11506# sh run
!Generated on 05/12/2007 17:00:20
!Active version: sg0720003
configure
!*************************** GLOBAL ***************************
ssl associate rsakey myrsakey1 CSSrsakey1
ssl associate cert myrsacert1 CSScertfile1
ssl associate rsakey myrsakey2 CSSrsakey2
ssl associate cert myrsacert2 CSScertfile2
ip route 0.0.0.0 0.0.0.0 204.101.28.161 1
!************************* INTERFACE *************************
interface 5/13
description "Client Side"
bridge vlan 10
interface 5/15
bridge vlan 20
description "Server side"
!************************** CIRCUIT **************************
circuit VLAN10
ip address 204.x.x.163 255.255.255.224
circuit VLAN20
ip address 10.10.10.1 255.255.255.0
!*********************** SSL PROXY LIST ***********************
ssl-proxy-list sslfrinew
ssl-server 97
ssl-server 97 vip address 204.101.28.166
ssl-server 97 cipher rsa-with-des-cbc-sha 10.10.10.10 80
ssl-server 97 cipher rsa-with-3des-ede-cbc-sha 10.10.10.10 80
ssl-server 97 cipher rsa-with-rc4-128-sha 10.10.10.10 80
ssl-server 97 cipher rsa-with-rc4-128-md5 10.10.10.10 80
ssl-server 97 rsacert myrsacert1
ssl-server 97 rsakey myrsakey1
ssl-server 97 urlrewrite 24 http://www.test.com
active
!************************** SERVICE **************************
service SSLFRIDAY
type ssl-accel
keepalive type none
slot 6
add ssl-proxy-list sslfrinew
active
service http_backend
ip address 10.10.10.10
port 80
protocol tcp
active
!*************************** OWNER ***************************
owner Dave
content SSLFriday
application ssl
add service SSLFRIDAY
protocol tcp
port 443
active
content decrypt_www
vip address 10.10.10.5
add service http_backend
port 80
protocol tcp
active
CSS11506#
Thanks again
Dave
gmarogi
Level 5
Level 5
Key and certificate generation may be necessary in instances when you do not have pre-existing keys or certificates for the CSS. REfer URL
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11000series/v6.10/configuration/advanced/guide/SSL
