CSS11506 problem after replace disk
julxu
Level 7
Level 7
Greeting
I have the disk replaced for my CSS11506, after replacement, I have problem with ssl rsa/cert files:
#sh ssl file | grep aaa
aaaRSAkey.pem                   PEM                  887
aaaCAcert.pem                     PEM                  1042
# clear ssl file aaaRSAkey.pem "aaapwd"
%%file aaaRSAkey.pem does not exist
I remember before I have copy pem files into CSS11506, I did use old PC card, after pass all the rsa/cert files,
after I restored startup configure, I had poweroff the box, took old PC card out, and put new one in, and poweron
the box again.
where the rsa/cert files located? is possible I can clean the miss now?
any comments will be appreciated
thanks in advance
julxu
ddastoli
Hi there.
Certs and keys are stored under c:/CertStore/ssl/
To access you must go in debug mode:
"llama" to enter debug mode
Once you are in llama mode, you can try to delete the file with command:
ap_file delete c:/CertStore/ssl/aaaRSAkey.pem
Hope this helps.
/dom
