03-14-2012 06:15 PM
can I ask a simple question?
can I hot plug a flash card into css11506 without power the machine off?
Any comments will be appreciated
Thanks in advance
julxu
03-14-2012 11:26 PM
Hello Julxu,
Here you have what you are looking for:
"Removing a PCMCIA Disk
To remove a PCMCIA disk from the CSS:
1. Power down the CSS.
2. Power off the chassis by setting the power switch (or switches) to the O (off) position.
3. Locate the failed disk. If necessary, remove the PCMCIA cover
4. Press the ejector to the right of the disk, and slide the disk out. Figure 2 illustrates ejecting the disk
from slot 0.
Installing a PCMCIA Disk
To install a disk (refer to the previous figures):
1. Properly ground yourself prior to handling the disk, as noted on the previous page.
2. Insert the disk in the PCMCIA slot.
Note After you install a disk, you must wait 10 seconds before you can reseat or remove it.
3. With a Phillips screwdriver, replace the PCMCIA disk cover, then tighten the spring-loaded screws.
4. Power on and boot the CSS.
5. If you:
– Replaced a System disk containing the CSS software, use the Offline Diagnostic Monitor menu
to configure a primary location (or secondary location in a two-disk CSS) from which the CSS
accesses the boot image. By using the Offline Diagnostic Monitor menu, you can select the
software version currently on the new disk, if it is the same software version that was installed
on the original disk, or instruct the CSS where to locate a different version of the CSS software
ADI file. Refer to the Cisco Content Services Switch Administration Guide for details on using
the Offline DM menu and on upgrading the CSS software."
Here you got the entire document:
Hope this helps!!!
Jorge
03-15-2012 12:16 AM
thank Jorge
I know the procedure on doc. however, I want know if it can be hot swap.
that is, if I do not power off the system, can I insert the card into spare port (slot1)? like other system done.
julxu
03-15-2012 05:07 AM
No unfortunately the CSS is not hot-swappable at all. You need to turn off the device, install, and restart
Jorge
