CV Device Managers - Application Error
marcin.mazurek
Level 2
Level 2
did anybody met th problem with runninv CVDM for Cat6500, CSM, SSL mod? After loggin in to http server on 6500 and starting java applet CVDM it stops loading with "Application Error - Exiting the application".
I've tried different browsers, and CVDM is latest versin - 1.1.
tia
beth-martin
Level 10
Level 10
Have you made any changes if the setup was working before? What is the version of firmware running on the Cat 6500?
