Denying clients to a VIP
nygenxny123
currently we have access lists that allow any traffic to the interfaces
however a new design has come up about setting up a new VIP and only allowing 6 hosts to that VIP
we still want to keep the any any on the interface-but
would I do this using class maps?
i would have to set up a new service policy too ..i would imagine
amacuz
Hi nygenxny123,
the easiest way is indeed to control which traffic is processed by the ACE via the ACL.
However you could do it this way (being SFARM1 your existing serverfarm)
class-map match-all MYCL
  2 match virtual-address 10.20.30.40 tcp eq www
class-map type generic match-any C-SRC-IP
  2 match source-address 1.1.1.1 255.255.255.255
  3 match source-address 2.2.2.2 255.255.255.255
  4 match source-address 3.3.3.3 255.255.255.255
policy-map type loadbalance generic first-match PM-SRC-IP
  class C-SRC-IP
    serverfarm SFARM1
  class class-default
    drop
policy-map multi-match MMPOL
  class MYCL
    loadbalance vip inservice
    loadbalance policy PM-SRC-IP
    loadbalance vip icmp-reply active
Still I would recommend to use the ACL.
Hope this helps,
Alessandro
