design question: ACE module connected to 2 different L3 engine while in bridge mode
RAMAN AZIZIAN
fellow engineers,
i have been working on a design model , where the ACE mldule will provide SLB for both virtual and real servers. we have been deploying several UCS systems and the customer would like to use the ACE as our Enterprise SLB layer
configured in bridcge mode.
the msfc within the 6509 provide the L3 routing. however we may extends multiple vlans (v160-v163) via nexus switch layer (7k,5k,2k) to a FW appliance which now is the svi interface for the extended vlans. these vlans will be configured on a dedicated context.
the extension is based on the bridge mode operation as follow:
need help with the following:
1) if i have 4 bvi's configured, do i need to have default route configured?
2) my total count for vlans are: v160-v163 for server vlans, and v101 is the management vlan. the svi for this vlan is on the msfc card. the server GW are pointing to each dedicated svi's on  the  FW+L3 apliance.
3) if my default route on the context is pointing to the v160 svi on the FW+L3 engine, will that prevent the return traffic for other vlans ( v161-v163) from the ace toward the client?
4) is default route neccessary if you hae the ace in bridge mode.
it was brought to my attention that if you have multiple vlans configured in bridge mode pointing to another L3 engine, then each vlan would have to be configured on seperate context since you can only have one default route per context.
i appreciate any feedback on this inquiry. if you need additional information please le me know.
thanks and best regards,
raman azizian
mruuth
Hi Raman,
You can have up to eight default routes in one context. What the ACE is doing with the entries is to create a ARP-entry with the name GATEWAY. If you need more then eight entries, just declare gateway as rservers. In that case the ARP-entry is stored as RSERVER instead of GATEWAY. The trick is to tell ACE to learn the MAC-address for the IP-address and store it int the ARP-table. The ACE never learn for itself a MAC-address. Don't forget mac-sticky enable on vlan's facing gateway.
I'm running one context in bridge mode and have 18 bvi's with FW and Router 6509 as gateways.
Exampel:
Interface to ROUTER 6509
interface vlan 300
  bridge-group 300
  no normalization
  mac-sticky enable
  access-group input BPDU
  access-group input alla
  access-group output alla
  service-policy input lb-int-vlan300
  no shutdown
rserver host 300GATEWAY
  ip address 164.135.121.47
  inservice
A#1/prod1# sho arp | i 164.135.121.47
164.135.121.47  00.08.e3.ff.fc.14  vlan300   RSERVER    4775   239 sec      up
A#1/prod1#
Interface to FIREWALL
interface vlan 802
  bridge-group 802
  no normalization
  mac-sticky enable
  service-policy input lb-int-vlan802
  no shutdown
rserver host 802GATEWAY
  ip address 192.168.137.1
  inservice
192.168.137.1   00.23.33.6a.bf.80  vlan802   RSERVER    4785   5 sec        up
Mats
