diable routing of management port.
clayton-price
I have not been able to find a way to not introduce the management ports IP/network in the routing table when using the newer CSS code. Is it possible to revert back to the behavior of prior releases of Webns?
Thanks!
Gilles Dufour
it shows in the routing table but there should be no routing between a normal port and the management port.
There is no way to prevent it to show up in the routing table.
Gilles.
Thanks.
With it in the routing table, it seems to prevent traffic from taking the correct path, which was via a different interface.
For example, I have a 192.168.252.0/24 network assigned to the management port. I also have some devices in that network I would like to route through the CSS to reach. This no longer works since my former static route for 192.168.252.0/24 is gone and replaced by the management port route.
