Disabling SSL 3.0 closure alerts in CSM with SSL module?
ravi.malghan
Hi: I have a CSM with a SSL module. How do I disable the CSM from sending SSL closure alerts to the client?
Also is there a way to increase the amount of time the CSM waits before it send the SSL closure alert. Looks like the default is 14 seconds.
Ravi
ravi.malghan
found my answer: ssl-server 20 unclean-shutdown
