Does ACE hide a port from url
b.youssef
Hi all,
i need help in configuring ACE 4710 to hide Oracle application server port (tcp 7777) from the URL.
the load balancing betwwen the two servers is functioning but i need to eleminate the port from url
the clients access to http://www.example.com or https://www.example.com but they see on their browsers http://www.example.com:7777.
i'm using this guide:
Thank you .
8 Replies 8
pablo.nxh
Level 3
Level 3
Hi buddy,
ACE will take care of port translation as long as you define your backend server ports under the serverfarm as follows:
rserver host DB-1
  ip address 192.168.1.11
  inservice
rserver host DB-2
  ip address 192.168.1.12
  inservice
serverfarm host DB
  rserver DB-1 7777
    inservice
  rserver DB-2 7777
    inservice
class-map match-all Database
  2 match virtual-address 172.16.51.30 tcp eq www
policy-map type loadbalance first-match SLB
  class class-default
    serverfarm DB
policy-map multi-match CLIENT_VIPS
  class Database
    loadbalance vip inservice
    loadbalance policy SLB
    loadbalance vip icmp-reply active
In this scenario the ACE receives traffic as http://mydomain.com (port 80) but the traffic is sent to the servers over port 7777.
This is completely transparent to the client, 7777 will not be shown at any time on client's browser.
__ __
Pablo
except if there are hardcoded links or 302 redirect sent by the application.
Hi all,
the configuration done on the ACE is as follows:
probe tcp ACE-PORTAL
  port 7777
  interval 10
  passdetect interval 2
  passdetect count 1
  open 1
rserver host portal1
  ip address 192.168.90.179
  inservice
rserver host portal2
  ip address 192.168.90.181
  inservice
serverfarm host portal
  probe ACE-PORTAL
  probe PING
  rserver portal1 7777
    inservice
  rserver portal2 7777
    inservice
sticky ip-netmask 255.255.255.255 address both portal-sticky
  timeout 30
  serverfarm portal
class-map match-all VIP-portal-http
  2 match virtual-address 192.168.90.185 tcp eq www
policy-map multi-match portal-policy-map
  class VIP-portal-http
    loadbalance policy portal-policy
interface vlan 10
  bridge-group 1
  access-group input BPDU-Allow
  access-group input portal-acl
  service-policy input portal-policy-map
  no shutdown
interface vlan 11
  bridge-group 1
  no shutdown
But i have usually the same result the tcp port 7777 appears on the client browser. i have used wireshark, the server sends an http error 302:
HTTP/1.1 302 moved temporarily
I have used this guide for Oracle:
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6906/prod_white_paper0900aecd804edab0.html
any other help.
Regards.
Hi all,
without ACE, the clients request http://www.xyz.com and on their browser they get
http://www.xyz.com:7777/portal/page?_pageid=257,1,257_1753518&_dad=portal&_schema=PORTAL
So they need to hide the port 7777 with ACE and just see http://www.lip.gov.ly/portal/page?_pageid=257,1,257_1753518&_dad=portal&_schema=PORTAL
with Wireshark the server sends HTTP/1.1 removed-temporarily.
new config:
rserver redirect REDIRECT-TO-HTTP
  webhost-redirection http://%h/%p 302
  inservice
serverfarm redirect HTTP-REDIRECT-SFARM
  rserver REDIRECT-TO-HTTP
    inservice
  probe ACE-PORTAL
  probe PING
    inservice
    inservice
sticky http-cookie HTTP sticky-HTTP
  cookie insert browser-expire
  timeout 720
  serverfarm portal
class-map type http loadbalance match-any PORTAL-HTTP
  2 match http url /portal.*
  3 match http url /portal*
class-map match-any VIP-portal-http
  3 match virtual-address 192.168.90.185 any
policy-map type loadbalance first-match portal-policy
  class PORTAL-HTTP
    sticky-serverfarm sticky-HTTP
  class class-default
    serverfarm HTTP-REDIRECT-SFARM
interface vlan 10
  bridge-group 1
  no shutdown
interface vlan 11
  bridge-group 1
  no shutdown
301-302 are not HTTP errors, they are HTTP redirect response codes.
If this redirect you're seeing was embedded into the code there's no much you can do as the ACE will not have that inspected.
Now if it was manually entered into the web server you could try to rewrite the response with an action list:
action-list type modify http RewriteHost
   header rewrite response location header-value "http://example.com:7777/(.*)"  replace  "http://example.com/%1"
Here you can check all the details about action list and how it is applied http://xrl.us/bidxyj
You may also need a parameter map to modify each response
parameter-map type http RewriteHost
    header modify per-request
__ __
Pablo
Hi all,
i have done the same configuration but it still not functioning, this is the configuration:
config:
access-list BPDU-Allow ethertype permit bpdu
access-list portal-acl line 1 extended permit ip any any
probe tcp HTTP7777
  port 7777
  interval 30
  passdetect interval 10
  open 1
probe icmp PING
  interval 3
  passdetect interval 60
  persistence-rebalance
  inservice
  inservice
  header rewrite response location header-value "http://www.example.com:7777/(.*)" replace "http://www.example.com/(.*)"
  probe HTTP7777
  probe PING
    inservice
    inservice
sticky ip-netmask 255.255.255.255 address source portal-sticky
  timeout 30
  replicate sticky
  serverfarm portal
class-map match-all VIP-portal-https
  2 match virtual-address 192.168.90.185 tcp eq https
  class class-default
    sticky-serverfarm portal-sticky
    action RewriteHost
  class VIP-portal-https
    appl-parameter http advanced-options RewriteHost
interface vlan 10
  bridge-group 1
  no shutdown
interface vlan 11
  bridge-group 1
  no shutdown
interface bvi 1
  ip address 192.168.90.190 255.255.255.240
  peer ip address 192.168.90.189 255.255.255.240
  no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.90.177
Note : if i add the line 3 (Red highligted) in the class-map, the url is functioning but the port 7777 still appears in the url, if we delete this entry the url is not functioning!!!!!
Any help.
Hi all,
Until now i have the same problem.
Any help .
Regards.
Please give us some live http header trace.
