Downgrade Operational Flash
chloi
Level 2
Level 2
I had a CSS11501, previously, I upgraded it to version 7.30 build 5. Automatically, the operational flash will be upgraded to 7.30 build 5 also..
But, I need to downgrade the software to 7.2 build 206 now. I had downgrade the s/w in the disk. But, the operational Flash still running ver. 7.3 Build 5. How can I downgrade the operational flash as well?
Thanks.
thamdani
Hi Choon,
If you upgrade the software you will see the change in operational flash ,however if you downgrade the software you will see operation flash always latest but that does not mean it is the Active software.Best way to see what is the Active software do "show run" at the top of output you will see the Active version.That is the Active software on CSS.
Tanveer
thamdani
Hi Choon,
Tanveer
