dql https help
mattstanyontall
Community Member
I am trying to redirect the following:
https://test.testdomain.com -> https://sub.domain.com/folder
Here is what I have, but I just can't get it to work.  Hopefully something silly I am missing!
service srv_REDIRECT
  keepalive type none
  type redirect
  no prepend-http
  ip address 1.1.1.1
  domain "https://sub.domain.com/folder"
  active
dql dql_REDIRECT_1
  description "REDIRECTS"
  domain test.testdomain.com
content con_REDIRECT
   vip address 192.168.1.170
   add service srv_REDIRECT
   port 443
   protocol tcp
   url "/*" dql dql_REDIRECT_1
   active
I don't seem to be able to use dqls when dealing with SSL.  The SSL is terminated on the servers not on the CSS.
Any help greatly appreciated.
Kind regards
Matt
jsirstin
Level 5
Level 5
Matt,
Unfortunately if the CSS is not terminating the SSL traffic you cannot have it do the redirction. You can only have the CSS send the redirct if it does the SSL termination and can see the packet in clear text.
Jim
OK, thanks for explaining this.
Makes sense, guess I'll have to do the redirect on the server.
Thanks again.
