End to End SSL with Cookie insert for Sticky config Help
RAMAN AZIZIAN
Good Day all,
Got a new request from my customer to provide SSL termination (Front-end and Back-End) on the ACE module.
The following is the list of requirements:
1) SSL Termination from Client to ACE - Key size 2048
2) SSL initiation toward the Real servers - Key size 1024
3) Cookie insert for sticky - Provided by the ACE
4) Predictor - Leasconn
5) Mode - Bridge
I  have been searching the forum and other sites, and I like to get a clarification on a few things that I am having problem understanding;
Thank you in advance for taking the time to read this and provide me feedback/suggestions:
1) My customer has provided the certificate for their application, which I need to import on ACE. question about this, Do I need a certificate for every VIP that I configure on the ACE for termination for any future requirements?
2) Do I need to install a certificate on the ACE toward (initiate) the real servers? If so, do I first generate the key, and the follow the instructions to request the CSR?
3) To create the cookie insert for the sticky, is the following commands all I need to apply:
     sticky http-cookie ACE-Insert web-sticky
      cookie insert browser-expire
      timeout 5
      serverfarm my_server_farm
4) If I have lab a lab environment, can the certificate be exported first, and then imported on the Production ACE, or each environment needs to have their own certificate?
Any sample configuration that someone could share would also be greatly apprecaited.
-Raman
5 Accepted Solutions
Hi Raman,
  Actually there is a little typo. Your understanding regarding probe is correct. The probe port  should be 443 as you pointed  or it should be probe http and not probe https if port 80- is being used.
Also, it is not mandatory to have two serverfarm in case of end to end ssl(if that is what you are asking after referring to the example). In short:
SSL Termination------>Client------>ace------>RSERVERS.
Communication between client and ACE is encrypted. Ace to rservers is clear text. So here you need rservers to listen on port 80 or 8081 etc. Probing should be on port 80.
SSL initiation------> In this case communication between ACE and rservers is encrypted. So probe should be port 443.
End to End SSL----> In this case you need rserver to listen on 443 and front end as well as backend is encrypted. Probing should be on 443.
Also, commands to troubleshoot ssl would be:
show stats crypto client
show stats crypto server
I hope this helps.
Kanwal
Hello Raman,
I would like to some comments to your questions:
Question 3: I guess I should have been little more clear about what I  am asking. What I meant to ask was, since there are 4 rservers in this  example, why are not all 4 rservers listed in each serverfarm configured  above.
is this by design to split the load for rservers listening on 443 or 80?
If, you have servers hearing on port 80 and 443, etc. When the ACE is taking the load balance decision it does not care that need to go to a server hearing on port 80 like in ssl termination or on port 443 like in end-to-end, it just picks one -good luck- if it chooses the correct port but also it might possible it selects another port which will fail, then that´s why it is not recommended to mix ports
Q 6: Are the probe configs correct and have they been applied to the right SF?
You can just leave the default values and test it and then progressively start adding features.
Jorge
Hello Raman,
Can you copy and paste the current configuration to take a look?(You can change the ip address due to security if you want)
Here you have a sample about how a END-TO-END SSL should look like:
class-map match-all L4-CLASS-HTTPS
  2 match virtual-address 172.16.0.15 tcp eq https
policy-map multi-match VIPs
  class L4-CLASS-HTTPS
    loadbalance vip inservice
    loadbalance policy HTTPS-POLICY
    loadbalance vip icmp-reply
    loadbalance vip advertise active
    appl-parameter http advanced-options http_parameter_map
    ssl-proxy server CISCO-SSL-PROXY
policy-map type loadbalance http first-match HTTPS-POLICY
  class class-default
    serverfarm SF-1
    ssl-proxy client CLIENT-SSL-PROXY
serverfarm host SF-1
  rserver S1 443
    inservice
  rserver S2 443
    inservice
  rserver S3 443
    inservice
  rserver S4 443
    inservice
rserver host S1
  ip address 192.168.0.200
  inservice
rserver host S2
  ip address 192.168.0.201
  inservice
rserver host S3
  ip address 192.168.0.202
  inservice
rserver host S4
  ip address 192.168.0.203
  inservice
ssl-proxy service CLIENT-SSL-PROXY
ssl-proxy service CISCO-SSL-PROXY
  key rsakey.pem
  cert slot2-2tier.pem
  chaingroup Chaingroup1
  ssl advanced-options PARAMETER_SSL
crypto chaingroup Chaingroup1
  cert inter.pem
parameter-map type http http_parameter_map
  persistence-rebalance
  set content-maxparse-length 8192
  set header-maxparse-length 8192
parameter-map type ssl PARAMETER_SSL
session-cache timeout 300
queue-delay timeout 1
Here you have a link about it:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA5_1_0/configuration/ssl/guide/endtoend.pdf
Jorge
Hello Raman,
Do you have something like this?
interface vlan 351
  description NDC private Client side interface
  bridge-group 35
  mac-sticky enable
  access-group input NDC-IEMP-IN
  access-group output NDC-IEMP-OUT
  service-policy input LAB-IEMP-SP
  no shutdown
interface vlan 451
  description NDC private Real server
  bridge-group 35
  no shutdown
class-map match-all LAB-IEMP-HTTPS-VIP
  description LAB-IEMP-HTTPS-VIP 192.168.1.50
  2 match virtual-address 192.168.1.50 tcp eq https
policy-map multi-match LAB-IEMP-SP
  class LAB-IEMP-HTTPS-VIP
    loadbalance policy LAB-IEMP-HTTPS-PM
  key tac-key.pem
  cert tac-cert.pem
  chaingroup tac-Chaingroup
crypto chaingroup tac-Chaingroup
cert tac-root.pem
cert tac-intermediate.pem
case-insensitive
  set header-maxparse-length 65535
  set content-maxparse-length 65535
  length-exceed continue
  parsing non-strict
policy-map type loadbalance first-match LAB-IEMP-HTTPS-PM
  class class-default
  sticky-serverfarm launchpad_dev_secure
sticky http-cookie ACE-insert launchpad_dev_secure
  timeout 5
  serverfarm LAB-IEMP-HTTPS
serverfarm host LAB-IEMP-HTTPS
  predictor leastconns
  rserver RS01 443
    inservice
  rserver RS02 443
    inservice
  rserver RS03 443
    inservice
  rserver RS04 443
    inservice
  rserver RS05 443
    inservice
rserver host RS01
  description RS01 192.168.1.194
  ip address 192.168.1.194
  inservice
rserver host RS02
  description RS02 192.168.1.195
  ip address 192.168.1.195
  inservice
rserver host RS03
  description RS03 192.168.1.196
  ip address 192.168.1.196
  inservice
rserver host RS04
  description RS04 192.168.1.197
  ip address 192.168.1.197
  inservice
rserver host RS05
  description RS05 192.168.1.198
  ip address 192.168.1.198
  inservice
Jorge
Hello Raman,
Yes, something like this:
ACE-M2/Admin# crypto import terminal tac-key
Please enter PEM formatted data. End with "quit" on a new line.
-----BEGIN RSA PRIVATE KEY-----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G0ZS2T47jCzRLFPT9TiBQlcZQtY49GfZ22OIv9P7sVM
84ALi9ECQQCLIGX9AwUBMJ9TQBbSOQkC0C5bxJ6jKeceTAxByYAF
-----END RSA PRIVATE KEY-----
quit
ACE-M2/Admin# crypto import terminal tac-cert
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
quit
ACE-M2/Admin# crypto import terminal tac-inter
quit
ACE-M2/Admin# crypto import terminal tac-root
quit
ACE-M2/Admin# sh crypto files
Filename                                 File  File    Expor      Key/
                                         Size  Type    table      Cert
tac-cert                              1874  PEM     Yes        CERT
tac-inter                             1964  PEM     Yes        CERT
tac-key                               887   PEM     Yes         KEY
tac-root                              1566  PEM     Yes        CERT
ACE-M2/Admin#
ACE-M2/Admin# crypto verify tac-key tac-cert
Keypair in tac-key matches certificate in tac-cert.
ACE-M2/Admin#
2) Now, we are going to configure the chain-group:
ACE-M2/Admin(config)# crypto chaingroup tac-chaingroup
ACE-M2/Admin(config-chaingroup)# cert tac-root
ACE-M2/Admin(config-chaingroup)# cert tac-inter
ACE-M2/Admin(config-chaingroup)# exit
ACE-M2/Admin# sh crypto chaingroup all
chaingroup tac-chaingroup contains:
  tac-root
  tac-inter
ACE-M2/Admin#
3) Now we are going to configure the ssl-proxy service:
ACE-M2/Admin(config)# ssl-proxy service tac-ssl-proxy
ACE-M2/Admin(config-ssl-proxy)# chaingroup tac-chaingroup
ACE-M2/Admin(config-ssl-proxy)# cert tac-cert
ACE-M2/Admin(config-ssl-proxy)# key tac-key
ACE-M2/Admin(config-ssl-proxy)# end
  key tac-key
  cert tac-cert
It sounds great it is working now.
Hope this helps.
Jorge
12 Replies 12
Kanwaljeet Singh
Hi Raman,
Below is an example :
The following example illustrates an end-to-end SSL configuration, which combines front-end SSL and back-end SSL. The ACE receives encrypted text from an HTTP client, and also transmits the encrypted data as cipher text to the SSL server. On the reverse side, the ACE decrypts the cipher text that it receives from the SSL server and sends the data to the client as clear text. The SSL-specific configuration elements appear in bold in the example.
access-list ACL1 line 10 extended permit ip any any
probe https GEN-HTTPS
  port 80
  interval 50
  faildetect 5
  expect status 200 200
probe http GEN-HTTP
  port 80
  interval 50
  faildetect 5
rserver SERVER1
  ip address 172.27.16.11
    inservice
rserver SERVER2
  ip address 172.27.16.12
    inservice
rserver SERVER3
  ip address 172.27.16.13
    inservice
rserver SERVER4
  ip address 172.27.16.14
    inservice
serverfarm host SFARM1
  description SERVER FARM 1 FOR SSL TERMINATION
  probe GEN-HTTPS
  rserver SERVER1 80
    inservice
  rserver SERVER2 80
    inservice
serverfarm host SFARM2
  description SERVER FARM 2 FOR SSL INITIATION
  probe GEN_HTTP
  rserver SERVER3 443
    inservice
  rserver SERVER4 443
    inservice
parameter-map type ssl PARAMMAP_SSL_TERMINATION
  cipher RSA_WITH_3DES_EDE_CBC_SHA
  cipher RSA_WITH_AES_128_CBC_SHA priority 2
  cipher RSA_WITH_AES_256_CBC_SHA priority 3
  version all
parameter-map type connection TCP_PARAM
  syn-data drop
  exceed-mss allow
parameter-map type http PARAMMAP_HTTP
  server-conn reuse
  case-insensitive
parameter-map type ssl PARAMMAP_SSL_INITIATION
  cipher RSA_WITH_RC4_128_MD5
  cipher RSA_WITH_RC4_128_SHA
  cipher RSA_WITH_DES_CBC_SHA
  cipher RSA_EXPORT_WITH_RC4_40_MD5
  cipher RSA_EXPORT1024_WITH_RC4_56_MD5
  cipher RSA_EXPORT_WITH_DES40_CBC_SHA
  cipher RSA_EXPORT1024_WITH_DES_CBC_SHA
  cipher RSA_EXPORT1024_WITH_RC4_56_SHA
  version all
ssl-proxy service SSL_PSERVICE_SERVER
  ssl advanced-options PARAMMAP_SSL_TERMINATION
  key MYKEY.PEM
  cert MYCERT.PEM
ssl-proxy service SSL_PSERVICE_CLIENT
  ssl advanced-options PARAMMAP_SSL_INITIATION
class-map type http loadbalance match-all L7_SERVER_CLASS
  description Sticky for SSL Testing
  3 match source-address 192.168.130.0 255.255.255.0
class-map type http loadbalance match-all L7_SLB-HTTP_CLASS
  2 match http url .*
class-map match-all L4_SSL-TERM_CLASS
  description SSL Termination VIP
  2 match virtual-address 192.168.130.11 tcp eq https
policy-map type loadbalance first-match L7_SSL-TERM_POLICY
  class L7_SERVER_CLASS1
    serverfarm SFARM1
    insert-http I_AM header-value "SSL_TERM"
    insert-http SRC_Port header-value "%ps"
    insert-http DEST_IP header-value "%id"
    insert-http DEST_Port header-value "%pd"
    insert-http SRC_IP header-value "is"
  class L7_SLB-HTTP_CLASS1
    serverfarm SFARM1
class-map match-all L4_SSL-INIT_CLASS
  description SSL Initiation VIP
  2 match virtual-address 192.168.130.12 tcp eq www
policy-map type loadbalance first-match L7_SSL-INIT_POLICY
  class L7_SERVER_CLASS2
    serverfarm SFARM2
    insert-http SRC_IP header-value "%is"
    insert-http I_AM header-value "SSL_INIT"
    ssl-proxy client SSL_PSERVICE_CLIENT
  class L7_SLB-HTTP_CLASS2
    serverfarm SFARM2
policy-map multi-match L4_SSL-VIP_POLICY
  class L4_SSL-TERM_CLASS
    loadbalance policy L7_SSL-TERM_POLICY
    ssl-proxy server SSL_PSERVICE_SERVER
    connection advanced-options TCP_PARAM
  class L4_SSL-INIT_CLASS
    loadbalance policy L7_SSL-INIT_POLICY
    loadbalance vip icmp-reply active
    appl-parameter http advanced-options PARAMMAP_HTTP
interface vlan 120
  description Upstream VLAN_120 - Clients and VIPs
  ip address 192.168.120.1 255.255.255.0
  fragment chain 20
  fragment min-mtu 68
  access-group input ACL1
  nat-pool 1 192.168.120.70 192.168.120.80 netmask 255.255.255.0 pat
  service-policy input L4_SSL-VIP_POLICY
  no shutdown
ip route 10.1.0.0 255.255.255.0 192.168.120.254
Regarding your questions:
Actually it depends on your requirement. You can use the same certificate but customer may not permit that.
You don't need a certificate installed on ACE for SSL initiation.
The commands for sticky insert by ACE are correct.
For testing purpose you can generate demo certs from verisign and various other CA's website. You can also take the actual certificate from the server and import it on the ACE for testing. You can use the same certificate for testing with various VIP's and serverfarms but in production it all depends iupon customer requirement.
Kanwal
Hello Raman,
Just to add some comments to what Kawal said:
What you are trying to do is called: "END TO END SSL configuration"
Here you have a link about it: http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Configuration_Examples_--_SSL_Configuration_Examples#Examples_of_End-to-End_SSL_Configurations
Then you just need the certificates for the first part but not for the ssl initiation.
Your sticky configuration looks fine.
In my testing lab, we have used the same certificates for different VIPs but you can test it anyway.
Since you have bridge mode, please make sure your servers point at the router in front of the ACE as their default gateway and not necessary the ACE.
Hope this helps, please check it out and let´s us know your feedback
Jorge
Hi Jorge and Kawal,
Thanks for providing this information.
I have been working in my lab trying to establish the test bed to run through the  SSL end to end topology.
Currently I have connected the ACE Module to IXIA test appliance, establishing a basic L4 SLB.
I am able to generate client traffic toward the VIP and the five Real servers I have configured in the serverfaram, and the test are all successful.
Of course when I configured the ACE for SSL termination/Initiation, I was not able to successfully run through the test.
Here's some questions that I like to get additional information:
1) Can the Cert and Key which comes with ACE be utilized for a test bed such as the one I have established, or do i need to import the Cert that my customer has provided. I will import the key/cert on the production ACE.
2) If the client is establishing connection via  HTTPS and not HTTP do I need to configure the Server farm for HTTP as shown in the example you have provided.?
3) Why are there two rservers assigned to each SF? Is this normal/best practice?
4) Why is there two different VIPs configured? Shouldnt the same IP address be used, but binded with each designated TCP port?
5) For parameter-map type ssl PARAMMAP_SSL_INITIATION, and Termination, do I need to list all the ciphers as shown in example or will ACE by default respond to the Cipher?
6) The probes associated with each SF, they appear to be reversed, meaning, if the rservers are using the port inheritance attribute (80, or 443), shouldnt the correct probe be applied to each one based on the protocol.
My apology for posting long questions on this, but I am unfortunately on a time crunch and I need to have this completed. Any additional feedback will be much appreciated.
raman
Hi Raman,
Please find the answers inline:
Yes you can use the key and cert which are there in ACE. Is this ACE30? Because there is no cert in ACE 20 or ACE10.
You need to have a serverfarm listening on port 443 if you want to configure end to end ssl termination while for ssl termination you have serverfarm listening on port 80 since only front end is encrypted or 443 traffic while the backend is port 80 traffic.
If you have only one rserver and it fails, nothing will work. If you have two rservers, load will be shared between the two and if one fails other will bear the full load. It is generally a good practice to have multiple rserver. In fact if you have only one server why bother to have a server load balancer unless you got it just for SSL offloading.
You can use the same IP address.
It should by default respond to all the ciphers that are there in ACE.
Please explain this question. I didn't get you on this.
Kanwal
RAMAN AZIZIAN
Hi Kanwal,
Please see the inline answers.. sorry I wasn't very clear. It has been a long day.. I am sure  you can relate.
  port 80 ----> Should this be 443
---  snip----
  probe GEN-HTTPS -------> should this be HTTP probe
  rserver SERVER1 80
    inservice
  rserver SERVER2 80
    inservice
  probe GEN_HTTP --------- should this be HTTPS probe
  rserver SERVER3 443
    inservice
  rserver SERVER4 443
    inservice
What are some good commands to use to verify the SSL Connections are being established, other than
Show service-policy summary or show serverfarm {SF_Name}
Thanks again for helping me out.
have a good day.
raman
Hi Raman,
I hope this helps.
Kanwal
Hello Raman,
Jorge
Hi Jorge/Kanwal,
So, I wish I could share good news and say I got it to work, but unfortunately I am still having problems. ••L
The attached document has the configs I have been using in my lab.
File name L4 SLB HTTP HTTPS is my base config that I used in my test be to have a good know working environment. This config provides L4 loadbalancing, where the SSL sessions are established between the Client and Real servers. The ACE does basic load-balancing. I have not applied any Sticky to either one of the configs, until I will be able to make it work in SSL. Trying to keep it as simple as possible.
The File ACE SSL Config is the actual configs for End to End SSL.
Here’s what I get when I apply the config.
All serverfarms are up (Real servers in operation mode)
Service Policy for each VIPS are up.
In my lab I have created a basic Web page on a Server, and I am able to pull it up when I type in the VIP IP address in the URL of the client.
However, looking at the wireshark capture, I don’t see the SSL traffic between the ACE and Real servers. It’s all appears to be in clear.
I also look at the stats on the ACE, like Show conn, and I am not able to see the connection between the two devices (client and Real server)
Anyway, could you guys look over the configs (ACE SSL Config) and let me know if I am doing the configs correctly.
I forgot to get the Wireshark capture from the server, so I can provide that as well if you need to see it.
Much thanks for your continue support!
Hello Raman,
  class class-default
    serverfarm SF-1
  rserver S1 443
    inservice
  rserver S2 443
    inservice
  rserver S3 443
    inservice
  rserver S4 443
    inservice
rserver host S1
  inservice
rserver host S2
  inservice
rserver host S3
  inservice
rserver host S4
  inservice
  key rsakey.pem
  cert inter.pem
Jorge
Hello Raman,
interface vlan 351
  bridge-group 35
  mac-sticky enable
  no shutdown
interface vlan 451
  bridge-group 35
  no shutdown
  key tac-key.pem
  cert tac-cert.pem
cert tac-root.pem
case-insensitive
  parsing non-strict
  class class-default
  timeout 5
  rserver RS01 443
    inservice
  rserver RS02 443
    inservice
  rserver RS03 443
    inservice
  rserver RS04 443
    inservice
  rserver RS05 443
    inservice
rserver host RS01
  inservice
rserver host RS02
  inservice
rserver host RS03
  inservice
rserver host RS04
  inservice
rserver host RS05
  inservice
Jorge
Hi Jorge,
Great News, I was finally able to make this work!!!
However, I did have to make a couple of changes to successfully establish the end to end SSL.
I removed the following parameter-map type http http_parameter_map from policy-map multi-match LAB-IEMP-SP
I didn't get a chance to investigate to see why the removing of this command helped the overall connectivity. I will be able to have more information tomorrow when I get back to work.
I have one more question to ask you in regard to importing the certificate and Key. Currently I am using the cert and key that came with the ACE30 Module. I am planning on importing the certificate that was provided to me by my customer.
The key file that I need to import, should that contain the Private Key info, or the public key, or both?
Thanks again for all your help to resolve this.
Best Regards,
-raman
Hello Raman,
quit
quit
quit
quit
ACE-M2/Admin#
ACE-M2/Admin#
  tac-root
  tac-inter
ACE-M2/Admin#
  key tac-key
  cert tac-cert
Hope this helps.
Jorge
