Error: Selected disk does not exist (21) Module-SRE-700
thiago.tomen
Community Member
Already tried everything that the recovery cisco commands, anyone have idea how to solve the problem of the print shown in print?
Initializing memory #2. Please wait...
This may take a minute....
Serial ATA Port 0 : Hitachi HTE545050B9A300
DDR Memory 4096 MB detected
Intel(R) Core(TM)2 Solo CPU    L3400  @ 1.86GHz
BIOS SM 3.52.8,  BIOS Build date: 02/08/2011
System now booting...
Please wait...
Please press P to select Primary Boot Loader ...
          or S to select Secondary Boot Loader ...
          or wait to boot from default configuration ...
Now booting from primary boot loader....
Authenticating boot loader....
Primary Boot Loader Authenticated - booting....
ServicesEngine boot-loader> install_key waas-accelerator-4.4.5c.4-k9.bin
Keyfile Size 202814577 over limit 32768 will not burn into flash
ServicesEngine boot-loader> verify
Loading disk:/bzImage ... Unable to load image
Unable to boot image
Unrecognized command
#service-module sm 1/0 session
Trying 172.20.245.1, 2067 ... Open
Please wait...
Please enter '***' to change boot configuration:
Trying to reset Service Module SM1/0.
May  7 11:27:33.055: %SRE_SM-6-STATE_CHANGE: SM1/0 changing state from SERVICE_MODULE_STATE_ERRQ to SERVICE_MODULE_STATE_SHDN
Initializing memory #1. Please wait...
Please wait...
Detect and Initialize network device
Backup current platform configurations....
SRE step 1 - SM registration...
Finding (hd1,3)/296e03bc-3236-4a68-a178-688e56400a1e, failed
Local install not supported
Response - no installation needed (len: 422)
SRE Installation Not Needed
Restoring orignial configuration...
Updating flash with bootloader configuration.
Please wait ................... done.
May  7 11:29:03.331: %SM_INSTALL-6-INST_RBIP: SM1/0 received msg: RBIP Registration RequestLoading disk:/bzImage ... Unable to load image
þ
Please wait...
May  7 11:30:31.339: %SM_INSTALL-6-INST_RBIP: SM1/0 received msg: RBIP Registration RequestLoading disk:/bzImage ... Unable to load image
ú
Please wait...
Felix Arrieta
Hello Thiago,
I did some research and most of similar cases were solved with RMA. You could request TAC for a Failure Analysis  to figure out further.
Saludos,
Felix
Opened a tac and managed to get the resolution of the problem. For those with the same problem reported by me above just follow the procedure below:
1. uninstall existing SRE-V software
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/sre_v/1.5/user/guide/software.html#wp1055364
2. run sm-hw-util to set sata mode to IDE
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/sre_v/1.5/user/guide/software.html#wp1091438
3. configure a static, 32bit route to point the service module IP address to the SM slot/0 interface
ip route 255.255.255.255 SM slot/0
4. install WAAS:
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v421/module/installation/guide/wssmcfg.html#wp47040
