Cisco ACE 20 - sticky radius attribute not working
Zarahelll
Hello to you all
I need your help. I´m trying to create a sticky group applied to my auth serverfarm based on the calling-station-id attribute, but for some reason when I apply the configs, I get not replies from my rservers. I´ve checked the radius servers, and no packets are getting to them. For some reason, when I create the sticky group the ACE 20 doesn´t distribute the traffic at all.
The service-policy is inservice, all the rservers are operational, but there´s no replies to my authentication requests, and no entries in the sticky database.
My current configs:
ADMIN context:
resource-class RADIUS-STICKY
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 10.00 maximum unlimited
context context-radius
member RADIUS-STICKY
CONTEXT-RADIUS context:
serverfarm host RADIUS-AUTH
  predictor leastconns
  probe RADIUS-PROBE-AUTH
  rserver RADIUS-01
    inservice
  rserver RADIUS-02
    inservice
  rserver RADIUS-03
    inservice
sticky radius framed-ip calling-station-id RADIUS-AUTH
serverfarm RADIUS-AUTH
timeout 5
policy-map type loadbalance first-match RADIUS-AUTH
  class class-default
    sticky-serverfarm RADIUS-AUTH
Am I missing anything?
Best wishes
Zarahelll
I figured it out
The loadbalance policy-map has to be set has a L7 Radius policy map:
policy-map type loadbalance radius first-match RADIUS-AUTH
  class class-default
It now inspects the Radius packets and is able to apply stickiness.
