Error: sticky resource not available
netternewbie
I get the following error when I try to add sticky config to a context.
I have added the following to the admin context but no joy:
resource-class **********
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 10.00 maximum equal-to-min
One thing I noticed is it is only on the admin context of one ace module. It ain't on the admin module of the other ace context. Do I need to add it manly to both? Afraid of putting them out of sync.
Can anyone please advise?
56 Replies 56
Hi Kanwal,
Seem to have lost connection since makes those changes. See output below:
sh service-policy ****-POLICY DE
Status     : ACTIVE
Description: -----------------------------------------
Context Global Policy:
  service-policy: ****-POLICY
    class: ****-HTTPS-VIP
      ssl-proxy server: SSL-****-PROXY
     VIP Address:    Protocol:  Port:
     *.*.175.110   tcp        eq    443
      loadbalance:
        L7 loadbalance policy: ****-HTTPS-POLICY
        Regex dnld status    : SUCCESSFUL
        VIP Route Metric     : 77
        VIP Route Advertise  : DISABLED
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        VIP State: INSERVICE
        curr conns       : 0         , hit count        : 0
        dropped conns    : 0
        client pkt count : 0         , client byte count: 0
        server pkt count : 0         , server byte count: 0
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
        L7 Loadbalance policy : ****-HTTPS-POLICY
          class/match : SSLCLASS
            ssl-proxy client : SSL_CLIENT
             LB action: :
               sticky group: STICKY-SSL-****-FARM
                  primary serverfarm: ****-FARM
                    state: UP
                  backup serverfarm : -
            hit count        : 0
            dropped conns    : 0
          class/match : class-default
             LB action: :
                    state: UP
            hit count        : 0
            dropped conns    : 0
    class: REDIRECT-HTTP-****
     *.*.175.110   tcp        eq    80
      loadbalance:
        L7 loadbalance policy: ****-POLICY-REDIRECT
        VIP Route Advertise  : ENABLED
        dropped conns    : 0
        L7 Loadbalance policy : ****-POLICY-REDIRECT
            LB action: :
               primary serverfarm: HTTP-****-FARM
                    state: UP
            hit count        : 0
            dropped conns    : 0
Actually I have changed VIP address so need to double check firewall now. Sorry.
Sorry for delayed response Kanwal. We had some problems here with other things. I will try what you suggested Monday morning and get the server guys to check their things.
I will let you know how I get on. Thanks for all your help and patience. Hopefully we get it sorted Monday.
Hi kanwal,
Unfortunately I am still having problems. Below is the current config. Do you see anything obvious that is wrong? At the moment the application is listening on 8443, there are certs on the two servers and there was a reverse proxy configured but this is turned off now.
crypto chaingroup ****-CHAINGRP
cert chain-ROOT
cert ****CAcert
probe tcp ****-WEB-PROBE
port 8443
interval 3
passdetect interval 5
parameter-map type ssl SSL-****-ADVANCED
cipher RSA_WITH_RC4_128_MD5
rserver host ****TC1
ip address *.*.*.*
inservice
rserver host ****TC2
ip address *.*.*.*
inservice
rserver redirect HTTP-****
webhost-redirection https://%h/%p 301
inservice
ssl-proxy service SSL-****-PROXY
key ****.pem
cert ****CAcert
ssl advanced-options SSL-****-ADVANCED
ssl-proxy service SSL_CLIENT
serverfarm host ****-FARM
predictor leastconns
probe ****-WEB-PROBE
rserver ****TC1 8443
inservice
rserver ****TC2 8443
inservice
serverfarm redirect HTTP-****-FARM
rserver HTTP-****
inservice
sticky ip-netmask 255.255.255.255 address source STICKY-SSL-****-FARM
timeout 720
timeout activeconns
replicate sticky
serverfarm ****-FARM
class-map match-any ****-HTTPS-VIP
3 match virtual-address *.*.*.* tcp eq https
class-map match-any REDIRECT-HTTP-****
3 match virtual-address *.*.*.* tcp eq www
class-map type http loadbalance match-all SSLCLASS
2 match http url .*
policy-map type loadbalance first-match ****-HTTPS-POLICY
class SSLCLASS
sticky-serverfarm STICKY-SSL-****-FARM
ssl-proxy client SSL_CLIENT
class class-default
policy-map type loadbalance first-match ****-POLICY-REDIRECT
class class-default
serverfarm HTTP-****-FARM
policy-map multi-match ****-POLICY
class ****-HTTPS-VIP
loadbalance vip inservice
loadbalance policy ****-HTTPS-POLICY
loadbalance vip icmp-reply active
ssl-proxy server SSL-****-PROXY
class REDIRECT-HTTP-****
loadbalance policy ****-POLICY-REDIRECT
loadbalance vip advertise
service-policy input ****-POLICY
Hi Netter,
Hmm..Let us do this way. If you configure a simple tcp port 8443 loadbalancing(nothing to do with ssl offloading) does it work?
So you will configure a VIP listening on port 8443 and if client comes on that VIP with dst port as 8443 the request would be sent to your server listening on 8443. If that works then we are sure that routing is fine and it is ssl configuration which is problem.
Can you test that?
Kanwal
Hi Netter,
And yes your config looks fine. Can you also get a pcap from client while testing the existing configuration?
Can you also send me output of show conn
Kanwal
Hi Netter,
Did you also test by removing SSL parameter ?
Kanwal
Hi Kanwal,
Yes I did but no luck. Would you like me to leave it removed or leave it on?  I am currently getting a connection timeout when I try hit the service in a browser. So maybe the server guys have changed something and I need to do something else.
HI Netter,
You can test it by removing it.
The best way to start  would be to see if the traffic is being forwarded from client or not by ACE and if server is replying or not. That way we can be sure that there is no routing problem.
Once that is confirmed we can start with SSL. The config above looks like. Just test it by removing the SSL parameter since you have selected only cipher there. Let it be at default and check.
Kanwal
Hi Netter,
yes please try with ssl parameter.
Kanwal
Hi Kanwal.
Removing it seems to have worked. Brilliant!!!!!!!! I will carry out more testing and let you know.
Thanks a million for all the help.
Kanwaljeet Singh
Hi Netter,
Wonderful. Let me know how it goes. I am very glad it worked.
Kanwal
