Error: sticky resource not available
netternewbie
I get the following error when I try to add sticky config to a context.
I have added the following to the admin context but no joy:
resource-class **********
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 10.00 maximum equal-to-min
One thing I noticed is it is only on the admin context of one ace module. It ain't on the admin module of the other ace context. Do I need to add it manly to both? Afraid of putting them out of sync.
Can anyone please advise?
56 Replies 56
Thanks Kanwal,
Looks like it's getting closer but still not there. If I type service name it redirects to https:// but gives a no data received error on web page.
If I go directly to each server on https://*.*.*.*:8443 it works. Am I missing somthing simple. Here is a few show commands:
sh probe ****-WEB-PROBE
probe       : ****-WEB-PROBE
type        : TCP
state       : ACTIVE
   port      : 8443    address     : 0.0.0.0         addr type  : -
   interval  : 3       pass intvl  : 5               pass count : 3
   fail count: 3       recv timeout: 10
                       --------------------- probe results --------------------
   probe association   probed-address  probes     failed     passed     health
   serverfarm  : ****-FARM
     real      : ****TC1[8443]
                       *.*.*.*    7834       127        7707       SUCCESS
     real      : ****TC2[8443]
                       *.*.*.*    7836       128        7708       SUCCESS
sh serverfarm ****-FARM
serverfarm     : ****-FARM, type: HOST
total rservers : 2
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver:****TC1
       *.*.*.*:8443     8      OPERATIONAL  0          0          44
   rserver: *TC2
       *.*.*.*:8443     8      OPERATIONAL  0          0          0
sh service-policy
Policy-map : ****-POLICY
Status     : ACTIVE
Context Global Policy:
  service-policy: ****-POLICY
    class: ****-HTTPS-VIP
      ssl-proxy server: SSL-****-PROXY
      loadbalance:
        L7 loadbalance policy: ****-HTTPS-POLICY
        VIP Route Metric     : 77
        VIP Route Advertise  : DISABLED
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        VIP State: INSERVICE
        curr conns       : 0         , hit count        : 363
        dropped conns    : 184
        client pkt count : 4051      , client byte count: 1056853
        server pkt count : 1765      , server byte count: 258936
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
    class: REDIRECT-HTTP-****
      loadbalance:
        L7 loadbalance policy: ****-POLICY-REDIRECT
        VIP Route Advertise  : ENABLED
        curr conns       : 0         , hit count        : 2
        dropped conns    : 0
        client pkt count : 8         , client byte count: 344
        server pkt count : 0         , server byte count: 0
Also here is the current config. Maybe I am missing something or extra still in config.
crypto chaingroup ****-CHAINGRP
  cert chain-ROOT
  cert ****CAcert
probe tcp ****-WEB-PROBE
  port 8443
  interval 3
  passdetect interval 5
parameter-map type ssl SSL-****-ADVANCED
  cipher RSA_WITH_RC4_128_MD5
rserver host ****TC1
  ip address *.*.*.*
  inservice
rserver host ****TC2
  ip address *.*.*.*
  inservice
rserver redirect HTTP-****
  webhost-redirection https://%h/%p 301
  inservice
ssl-proxy service SSL-****-PROXY
  key ****.pem
  cert ****CAcert
  ssl advanced-options SSL-****-ADVANCED
ssl-proxy service SSL_CLIENT
serverfarm host ****-FARM
  predictor leastconns
  rserver ****TC1 8443
    inservice
  rserver ****TC2 8443
    inservice
serverfarm redirect HTTP-****-FARM
  rserver HTTP-****
    inservice
sticky ip-netmask 255.255.255.255 address source STICKY-SSL-****-FARM
  timeout 720
  timeout activeconns
  replicate sticky
class-map match-any ****-HTTPS-VIP
  2 match virtual-address *.*.*.* tcp eq https
class-map match-any REDIRECT-HTTP-****
  2 match virtual-address *.*.*.* tcp eq www
policy-map type loadbalance first-match ****-HTTPS-POLICY
  class class-default
    sticky-serverfarm STICKY-SSL-****-FARM
    ssl-proxy client SSL_CLIENT
policy-map type loadbalance first-match ****-POLICY-REDIRECT
  class class-default
    serverfarm HTTP-****-FARM
policy-map multi-match ****-POLICY
  class ****-HTTPS-VIP
    loadbalance vip inservice
    loadbalance policy ****-HTTPS-POLICY
    loadbalance vip icmp-reply active
    ssl-proxy server SSL-****-PROXY
  class REDIRECT-HTTP-****
    loadbalance policy ****-POLICY-REDIRECT
    loadbalance vip advertise
service-policy input ****-POLICY
Hi Netter,
My apologies but i was not entirely right. For end to end ssl it a requirment that you create a layer 7 class map. So you would need to make changes to the configuration. Let me paste one example for you:
class-map type http loadbalance match-all SSLCLASS
  2 match http url .*
Then you need to call this class under policy map.
Class SSLCLASS
Stikcy serverfarm STICKY-SSL-****-FARM
class class-default
Other than that it is looking fine.
Please try and let me know how it goes.
I tested with 443 backend and it worked. Couldn't test with backend 8443. But i think it should work fine.
Kanwal
Hi Kanwal,
No joy unfortunately. This is what I have changed,
  class SSLCLASS
  class class-default
  class class-default
total rservers : 2
   rserver: ****TC1
       *.*.*.*:8443     8      OPERATIONAL  0          0          88
   rserver: ****TC2
       *.*.*.*:8443     8      OPERATIONAL  0          0          5
                   Hi Netter,
You didn't configure the L7 class map. Can you configure the L7 class map as shown in config i pasted in last post and see how it goes.
Kanwal
Sorry Kanwal, I had it in. Here are the classes I have:
  2 match http url .*
Thanks again for your thorough help on this.
Hi Kanwal, This is actually the full config I have now. Does it look ok to you?
cert chain-ROOT
cert ****CAcert
port 8443
interval 3
ip address *.*.*.*
inservice
ip address *.*.*.*
inservice
inservice
key ****.pem
cert ****CAcert
inservice
inservice
rserver HTTP-****
inservice
timeout 720
timeout activeconns
replicate sticky
2 match http url .*
class SSLCLASS
class class-default
class class-default
Hi Netter,
Yes this looks good.
Kanwal
Thanks Kanwal. I now get this error though:
The connection was reset
The connection to the server was reset while the page was loading.
   *   The site could be temporarily unavailable or too busy. Try again in a few
          moments.
    *   If you are unable to load any pages, check your computer's network
          connection.
    *   If your computer or network is protected by a firewall or proxy, make sure
          that Firefox is permitted to access the Web.
I there anything else I can do? Do you think there is something still wrong with my config? I am really stuck now.
Thanks Again,
Hi Netter,
The config looks fine.
Send me the below output:
show service-policy detail.
Ensure that you don't need NAT. What is your serve's default gateway?
Is routing proper?
Kanwal
Thanks Kanwal, here is the output. We use public addresses so I don't think I need NAT. We have another service running in this context and it is fine. The default gateway of servers with be gateway of Van: *.*.*.1.
sh service-policy ****-POLICY detail
Status     : ACTIVE
Description: -----------------------------------------
     VIP Address:    Protocol:  Port:
     193.1.174.104   tcp        eq    443
      loadbalance:
        Regex dnld status    : SUCCESSFUL
        curr conns       : 0         , hit count        : 467
        dropped conns    : 282
        client pkt count : 5054      , client byte count: 1206294
        server pkt count : 2068      , server byte count: 272134
        L7 Loadbalance policy : ****-HTTPS-POLICY
          class/match : SSLCLASS
            ssl-proxy client : SSL_CLIENT
             LB action: :
               sticky group: STICKY-SSL-****-FARM
                  primary serverfarm: ****-FARM
                    state: UP
                  backup serverfarm : -
            hit count        : 82
            dropped conns    : 0
          class/match : class-default
             LB action: :
                    state: UP
            hit count        : 0
            dropped conns    : 0
     *.*.*.*   tcp        eq    80
      loadbalance:
        curr conns       : 0         , hit count        : 24
        dropped conns    : 0
        client pkt count : 99        , client byte count: 7933
        L7 Loadbalance policy : ****-POLICY-REDIRECT
            LB action: :
               primary serverfarm: HTTP-****-FARM
                    state: UP
            hit count        : 6
            dropped conns    : 0
Hi Kanwal, the VIP is actually a different subnet to servers so maybe this is the problem. I will change the IP of the VIP and change it in the context and see if it makes any difference.
                   Hi Netter,
We are getting hits on the policy as well as on sslclass but there are drops on L3 policy map.Can you also remove SSL parameter map from both ssl client proxy as well as server and give it a try.
VIP can be different as long as there is a route to it from uplink. Once traffic matches it will be loadbalanced to servers in serverfarm. Now servers should be able to send the traffic back (if ace is their GW or servers have a route towards ace or you do NAT so that traffic comes back  to ACE).
When you establish a connection what do you see in "show conn"? You can filter using your testing client IP address or VIP. So you can use show conn . Send me that output as well.
Also, ensure that policy is applied to the correct interface vlan. It should be applied to client facing VLAN.
Kanwal
Sorry Kanwal, how or what do I remove. Is it like line bolded below:
ssl-proxy service SSL-FILR-PROXY
  key filr.pem
  cert filrCAcert
  chaingroup FILR-CHAINGRP
NO  ssl advanced-options SSL-FILR-ADVANCED
Hi Netter,
Yeah that is right.
Kanwal
