Error: sticky resource not available
netternewbie
I get the following error when I try to add sticky config to a context.
I have added the following to the admin context but no joy:
resource-class **********
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 10.00 maximum equal-to-min
One thing I noticed is it is only on the admin context of one ace module. It ain't on the admin module of the other ace context. Do I need to add it manly to both? Afraid of putting them out of sync.
Can anyone please advise?
56 Replies 56
Hi Netter,
My pleasure in assisting you. Get me the configuration and we will see what is going on here.
Kanwal
Thanks Kanwal. Here is the current config. I think I am on right track.
crypto chaingroup ****-CHAINGRP
  cert chain-ROOT
    cert ****CAcert
crypto csr-params CSR-PARAMS
  country
  state
  locality
  organization-name
  organization-unit
  common-name ****.co.uk
  serial-number 601
access-list BPDU ethertype permit bpdu
probe tcp ****-WEB-PROBE
  interval 3
  passdetect interval 5
parameter-map type ssl SSL-****-ADVANCED
  cipher RSA_WITH_RC4_128_MD5
rserver host ****TC1
  ip address *.*.*.*
  inservice
rserver host ****TC2
  ip address *.*.*.*
  inservice
rserver redirect HTTP-****
  webhost-redirection https://%h/%p 301
  inservice
ssl-proxy service SSL-****-PROXY
  key ****.pem
  cert ****CAcert
  ssl advanced-options SSL-****-ADVANCED
serverfarm host ****-FARM
  predictor leastconns
  probe ****-WEB-PROBE
  rserver ****TC1 80
    inservice
  rserver ****TC2 80
    inservice
serverfarm redirect HTTP-****-FARM
  rserver HTTP-****
    inservice
sticky ip-netmask 255.255.255.255 address source STICKY-SSL-****-FARM
  timeout 720
  timeout activeconns
  replicate sticky
  serverfarm ****-FARM
class-map match-any ****-HTTPS-VIP
  2 match virtual-address *.*.*.* tcp eq https
class-map match-any REDIRECT-HTTP-****
  2 match virtual-address *.*.*.* tcp eq www
policy-map type loadbalance first-match ****-HTTPS-POLICY
  class class-default
    sticky-serverfarm STICKY-SSL-****-FARM
policy-map type loadbalance first-match ****-POLICY-REDIRECT
  class class-default
    serverfarm HTTP-****-FARM
policy-map multi-match ****-POLICY
  class ****-HTTPS-VIP
    loadbalance vip inservice
    loadbalance policy ****-HTTPS-POLICY
    loadbalance vip icmp-reply active
    ssl-proxy server SSL-****-PROXY
policy-map multi-match ****REDIRECTPOLICY
  class REDIRECT-HTTP-****
    loadbalance policy ****-POLICY-REDIRECT
    loadbalance vip advertise
service-policy input ****REDIRECTPOLICY
service-policy input ****-POLICY
Hi Netter,
The configuration looks absolutely fine to me.
So this configuratio didn't work? You said there was redirection loop which  i assume could happen because client didn't come with https url to which it was redirected otherwise it would have matched a different class and loadbalanced to different serverfarm.
Can you capture on client itself and see what URL client goes with after it has been redirected? That should tell us why the redirection is happening again and again.
You can also install iehttp for IE or Live utility in Mozilla to see the HTTP based communication between client and server(ACE).
And you don't need to define two policy mutli-match. You can simply call both class maps under the same policy mutli match. If it doesn't match the first class, it will look into second and so on. Once a match is done it stops.
Kanwal
Hi Kanwal,
Just got word from the server guys  server runs on 8443. Do I just change
  rserver ****TC1 80
    inservice
  rserver ****TC2 80
to
  rserver ****TC1 8443
    inservice
  rserver ****TC2 8443
Hi Netter,
If the server is listening on 8443 then backend connection would be SSL too which means you need to do end to end ssl loadbalancing or you can simply loadbalance based on TCP port and if you do so you need to remove SSL proxy configuration.
For end to end ssl you have to configure ACE both as ssl server and client and configuration will need a slight change. Please go through the below link for same.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_1_0/configuration/ssl/guide/endtoend.html
Let me know if have any questions.
Kanwal
Thanks Kanwal,
To be honest I am knew to all this so haven't a clue which is best way to proceed. What way would you think is best? Would it be hard to change my current config to do end to end loadbalancing? Not sure where to start.
    Hi Netter,
    To configure end-to-end SSL you need to make couple of changes and they are not big. Please go through the link and it will give you an idea of what you are missing.
Regarding what you should is absolutely your decision. Normally SSL offloading is done on ACE to relieve servers of cpu intensive SSL handshake which may impact their performance and also take decisions on the basis of data which ACE otherwise cannot see if it is not doing SSL ofloading.
In end to end ssl even backend connection is encrypted which means that you don't care about performance impact but you may still need ACE to look into data for LB decisions. If you don't need that you can simply tell ACE to LB on the basis of TCP port and connection would be encrypted from client to server and ACE would just do LB.
Honestly, it is your decision based on your requirement. If you don't want ACE to do anything by looking into decrypted packet then i would suggest go for TCP port based load balancing.but still your decision.
You can also go through the link for more details regarding end to end ssl which explains in detail about it.
If you have any questions please let me know.
Kanwal
Thanks Kanwal,
The service has to run on 8443 if they disable redirects so guess I have to do end-to-end SSL. I will give it a go and let you know how I get on.
I don't think I can do it on tcp port as client may connect on 80 or 443 from a web browser.
Hi Netter,
You are welcome. It is your choice as i said. But you can use redirection for port 80 and normal LB for 443 or end to end ssl. For end to end ssl you just need to make a minor change which you can see in the link i pasted. You have to add ssl-proxy client statement under policy-map type first match.
Let me know if you have any questions.
Kanwal
Thanks Kanwal,
Doing that now. I am worried do I need to do this part.
interface vlan 210
ip address 10.10.2.1 255.255.255.0
  service-policy input L7_1
  access-group input ACL
  no shutdown
Do I need to add
service-policy input L7_1? There are servers already live in this context and I am afraid this will break them.
Hi Netter,
I am not sure what this policy is. If the connections  already working don't match what this service policy (class map conditions) has then there should be no problems.
You can do this without breaking any existing connections. If you are not sure you can try this in off time.
Kanwal
Sorry thats just from the config in link you sent me. I will send what I have done now. I think I am totally lost to be honest.
Hi Kanwal,
Here is my current config. Is it totally wrong? Policy map L7_1 appears as offline.
cert chain-ROOT
  cert ****CAcert
access-list ALL line 8 extended permit ip any any
access-list ALL line 16 extended permit icmp any any
port 8443
interval 3
parameter-map type ssl PM1
session-cache timeout 300
queue-delay timeout 1
ip address *.*.*.*
inservice
ip address *.*.*.78
inservice
inservice
key ****.pem
cert ****CAcert
ssl-proxy service SSL_CLIENT
ssl advanced-options PM1
ssl-proxy service SSL_SERVER
key ****.pem
cert ****CAcert
inservice
inservice
rserver HTTP-****
inservice
timeout 720
timeout activeconns
replicate sticky
class-map type http loadbalance match-any SSL
2 match http url .*
class-map match-any SSL_C1
3 match virtual-address *.*.*.* tcp any
class class-default
class class-default
policy-map type loadbalance first-match SSL_BACK
class SSL
ssl-proxy client SSL_CLIENT
policy-map multi-match L7_1
class SSL_C1
loadbalance policy SSL_BACK
ssl-proxy server SSL_SERVER
interface vlan 303
bridge-group 303
no normalization
mac-sticky enable
access-group input BPDU
access-group input ALL
no shutdown
interface vlan 603
bridge-group 303
no normalization
mac-sticky enable
no shutdown
interface bvi 303
ip address *.*.*.* 255.255.254.0
peer ip address *.*.*.* 255.255.254.0
no shutdown
ip route 0.0.0.0 0.0.0.0 *.*.*.1
Hi Netter,
As per your requirement which i have understood after our discussion, you don't need to do any major. Please see the bold lines that you need to add and you should have end to end ssl configuration.
cert chain-ROOT
cert ****CAcert
country
state
locality
organization-name
organization-unit
serial-number 601
interval 3
ip address *.*.*.*
inservice
ip address *.*.*.*
inservice
inservice
key ****.pem
cert ****CAcert
inservice
inservice
rserver HTTP-****
inservice
timeout 720
timeout activeconns
replicate sticky
class class-default
class class-default
Let me know how it goes.
Kanwal
Thanks a million for all your help. I'll give this a go tomorrow and let you know how it goes.
