Error while telnet to ACE module!!!
sumaiyausa
Level 2
Level 2
Hi ,
I am not able to telnet to my ace module please see the error/msg i see when i try to login:-
[Switch6500]$ telnet acemod2
Trying 10.10.10.2.
Connected to acemod2.asia.com
acemod2 login: admin
Password:
Context not found, called API timed out
Trying 10.10.10.2....
Connected to acemod2.asia.com.
Escape character is '^]'.
Error: context name (id:0) cannot be determined.
Any help on this will be highly appriciated.
Sum.
5 Replies 5
dario.didio
Level 9
Level 9
are you trying to telnet the Admin context or another context?
Can you try to access it via the C6500?
use following command from the supervisor of your C6500:
session slot "slot number of ACE module" processor 0
Does this work?
hi,
yes this works. Console works fine as well. In regards to telnet it was working fine before but dont know it stopped working now.
Reg,
Sum.
litrenta
Level 8
Level 8
This is most likely a result of aclmerge process pegging cpu. from console do:
show proc cpu | inc aclmerged
see if processes are high.
aclmerge performance was improved in A2(2.x) code
Hi Letrenta,
Now I am facing the issue while try to get into the ACE from cat 6500 switch.
C6509#session slot 2 processor 0
What can i do now???
Sum
It looks as if you are hitting CSCsv98101
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsv98101
Did you reload the ACE module and see if it fixes it?
Syed
