f5-asm and ace forward and reverse traffic
anand kumar
Hi all,
In our datacentre setup , we have f5 asm & ace- cisco for loadbalancing
in which f5 is configured with  self ip& below the selfip,the  nodeip is there which is inturn the
virtual ip for Ace t2 context
the incoming traffic on f5 is like
Publicip:xx--> f5.selfip:80-->Ace virtualip:yy
for the ace request handling is of below
Ace.virtualip:yy-->Rserver:xx
but here the issue is that reverse http response flow is some what not analogous
rserver:xx-->f5.selfip:80 & back to the Public ip
myquery is that why the reply back from the rserver is not given back to ace virtual ip, but to the
selfip of f5
Daniel Arrondo Ostiz
Good morning,
You need to configure your routing in a way that the return traffic goes through the ACE. If you don't,  you may end up in the situation you are seeing
Daniel
Thanks Daniel, will go for routing Configured on Ace for reversepath
