Failover ACE, default route redundancy
IP Xpert
Level 3
Level 3
Hello!
Simple question - Since the ACE supports only static routing, when pointing a default route from the ACE what is your preferred method when using multiple 6500s with an ACE in each in a failover scenario to prevent just pointing at one 6500? Static route to an HSRP address? Multiple static routes on the ACE, etc?
Thanks!
Daniel Arrondo Ostiz
Hi Ben,
Probably, the best approach is what you already mentioned. Using the HSRP address of the 6500 as default gateway.
Daniel
Gotcha - thanks!
