WAAS Mobile Cluster limitation
aviyoshi10
i want to design a wass mobile cluster solution.
currently i have a single cluster (Single site) comprised of two servers (primary and backup) in my main data center  which is working.
i want to increase my backup by installing additional single server in each of the 3 backups data centers.
meaning, at the end i need single cluster comprising of 5 server which only one server acting as the primary. servers are not on the same LAN - need cluster over L3 WAN.
each data center gives me the same applications and data so no worry on that thing.
the question is can i do it ?, what is the cluster limitations ?
thanks,
Avi.
ktunugun
Hi Avi,
Yes you can configure redundant servers within a farm and redundant server farms in different data centers. A farm may contain a single server or multiple servers.
Kiran.
