Forcing stick entries to be removed
michael.e.reid
Hi, I think the sticky entries in our CSS are in their for too long. This causes an issue with uneven load on servers in the farm.
The sticky-inact-time does not automatically remove the entry when the timer expires, unless there is a new entry.
Is it possible to force the entry to be removed after a period of time.
cheers,
Mike
bstremp
Level 2
Level 2
The ssl-l4-fallback command is applicable only when the advanced-balance ssl method is specified for a content rule, which forces the content rule to stick to a server based on SSL version 3 session ID. The use of the ssl-l4-fallback command may be necessary in a lab environment when testing SSL with a small number of clients and servers, where some retransmissions might occur. In this case, you would not want to use the Layer 4 hash value because it will skew the test results
