FW load-balancing with CSM
edaguet
Dear all,
I have little question:
What is the TCP timeout on CSM between for a request (ex a SYN) and a response (SYN/ACK)?
Are the reverse-sticky with predictor leastconns or predictor hash only for FTP-like application? Why do you use reverse-sticky?
And last question:
if i use the predictor forward to forward traffic through CSM, ( i suppose that thet traffic is matched by the 5 CPU of the CSM), is CSM add latency time
on the request ? (i use 2 CSM via FW Load-balancing on each part - and i have 5 parts)
FYI: I load-balance FW through CSM without reverse-sticky and sticky. It is worked. Yesterday, the application didn't work. So i put sticky and reverse sticky (as Cisco recommend) , and my manager said me that it is not a solution but a workaround...
Not applicable
