global load balancing/active active vip and virtual interface redundancy
victor
Is there a way to configure both of these technologies without exposing the external addressing to the internal network? I have active active within the data center and would like to have active/active across two data centers but I don't see any way to use internal addressing for my content rules and still use them for dns unless I can specify records without using content rules. Thanks.
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a008009438a.shtml
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a0080157898.html
madittmer
Hi Victor,
In response to your questions regarding doing Active/Active GSLB using VIP and interface redundancy.
Rule Based GSLB will not work with VIP/Interface
redundancy.
The reason is because the CSS can not set up an app session to a redundant
interface, it needs to set the app session up to a real interface. Thus, a
full mess topology must be used for GSLB and vip/interface redudancy.
Bug ID CSddw27861 reported this problem and engineering added the command
"ap-kal-vip" to support a full mess topology. This command can only be used
under zone based GSLB and not rule based.
The syntax for the command would be:
dns-record a www.work.com 5.5.5.5 0 single kal-ap-vip 1.1.1.1
rule/ACL based GSLB with vip/int redundancy will not work.
Mark
