GSS - Interim Primary unable to connect to interim Standby
matthew-watson
I have failed over the GSSMs using the "gss primary-to-standby" (on the primary)command, followed by "gss standby-to-primary" (on the standby).
The failover worked successfully, with the execption of the following error message on the interim standby:
Feb 14 15:16:25 pnbgss001-uksr CRM-5-ASERVCANNTCONN[27886] unable to connect to HOST
155.x.x.x:3004 Connection refused
Feb 14 15:17:04 pnbgss001-uksr last message repeated 12 times
Can anyone explain the message further?
andrew.burns
Level 7
Level 7
Is there a firewall between them? If there is, does it have TCP ports 3002-3008 open in both directions?
Andrew.
Yes there are two pairs of Nokias both permitting the 3004 traffic.
No logs on the interim standby GSS to state it is rejecting a connection though.
Matt
