CRL retrival in SSLM module
lukaszkhalil
Hello
I am wondering which interface does the SSLM module use to retrive the CRLs - administrative or production ?
Thank you in advance
Lukas
amritpatek
Level 6
Level 6
The SSLM module uses the production interface to retrieve the CRL's. Following link may help you
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.10/configuration/ssl/guide/overview
Hello
Thanks, for help. The document you have send me is about CSS. We are using the SSL module for 6500.
I found the required information in the documentation for the SSL modules. SSLM is using managment vlan to download the CRLs.
I do not know how I missed this information previously.
I have tested it and it works as it is described in the documentation, by anyway thanks for your help.
Lukas
