GSS : KAL-AP statistics question
yves.haemmerli
When edisplaying the KAL-AP keepalive statistics in the CLI, I see the following :
IP: 141.122.169.195
Keepalive => 141.122.169.183
Status: ONLINE
Keepalive Type: Shared, Standard
Tag: "PORTAL-LETD"
Hash Secret: "1ab2c3"
Primary Circuit: 141.122.169.183
Load: 2
Circuit Transitions: 0
VIP Failovers: 0
Packets Sent: 2317
Packets Received: 2315
Positive Probe: 2315
Negative Probe: 2
Transitions: 18
VIP GID: 128 LID: 7
Keepalive GID: 111
Is it correct to deduce that the VIP never transitionned from up to down in KAL-AP reports, but the KAL-AP keepalive itself failed 18 times ? If yes, why the negative probe count is only 2 ?
Thank you
Yves Haemmerli
wdrootz
Level 4
Level 4
On the GSS:Show statistics keepalive kalap all
On the CSS:Show app-udp global
With these two commands you should be able to see the datagramssent/received.
