HA - ACE20-MOD-K9 - FT Group Config Will Not Synch (SSL)
We have a pair of ACE20-MOD-K9 in Fault Tolerant mode. They are running multiple contexts and we have a problem with one particular context which is running SSL off-loading. Despite the config being identical on both (accept for the peer addresses obviously) and both having the same SSL Key and Cert files loaded on both, the configuration will not sync between them.
Here is the outputs from both:
XXXX-DC2-00-ACE1/XXXXX-CISCO-QUAD-SERVICES# sh ft group brief
FT Group ID: 8  My State:FSM_FT_STATE_ACTIVE    Peer State:FSM_FT_STATE_STANDBY_COLD
                Context Name: XXXXX-CISCO-QUAD-SERVICES        Context Id: 2   Running Cfg Sync Status: Successful
XXXX-DC1-00-ACE1/XXXXX-CISCO-QUAD-SERVICES# sh ft group brief
FT Group ID: 8  My State:FSM_FT_STATE_STANDBY_COLD      Peer State:FSM_FT_STATE_ACTIVE
                Context Name: XXXXX-CISCO-QUAD-SERVICES        Context Id: 11  Running Cfg Sync Status: Successful
XXXX-DC2-00-ACE1/XXXXX-CISCO-QUAD-SERVICES# sh ft group stat
FT Group                     : 8
Configured Status            : in-service
Maintenance mode             : MAINT_MODE_OFF
My State                     : FSM_FT_STATE_ACTIVE
Peer State                   : FSM_FT_STATE_STANDBY_COLD
Peer Id                      : 1
No. of Contexts              : 1
Running cfg sync status      : Peer in Cold State. Incremental Sync Failure: SSL Keyfile does not exist
Startup cfg sync status      : Peer in Cold State. Incremental Sync Failure: SSL Keyfile does not exist
XXXX-DC1-00-ACE1/XXXXX-CISCO-QUAD-SERVICES# sh ft group stat
FT Group                     : 8
My State                     : FSM_FT_STATE_STANDBY_COLD
Peer State                   : FSM_FT_STATE_ACTIVE
Peer Id                      : 1
No. of Contexts              : 1
Running cfg sync status      : Incremental Sync Failure: SSL Keyfile does not exist
Startup cfg sync status      : Incremental Sync Failure: SSL Keyfile does not exist
XXXX-DC2-00-ACE1/XXXXX-CISCO-QUAD-SERVICES# sh crypto file
Filename                                 File  File    Expor      Key/
                                         Size  Type    table      Cert
fn42604_cert.pem                         1850  PEM     Yes        CERT
fn42604_privatekey.pem                   1679  PEM     Yes         KEY
quad2.pem                                1675  PEM     Yes         KEY
quad2_cer.pem                            2582  PEM     Yes        CERT
quad_prod_abbrv                          1675  PEM     Yes         KEY
quad_prod_abbrv_cer.pem                  2556  PEM     Yes        CERT
quad_prod_fqdn                           1675  PEM     Yes         KEY
quad_prod_fqdn_cer.pem                   2578  PEM     Yes        CERT
XXXX-DC1-00-ACE1/XXXXX-CISCO-QUAD-SERVICES# sh crypto file
All the Crypto files are identical as I copied them from one ACE to the other.
Can anyone shed any light on why this context is not syncing its configuration?
Dom Wilkinson
sivaksiv
Can you restart autosync and see if it fixes the issue,
no ft auto-sync startup-config
no ft auto-sync running-config
Siva
sivaksiv
Siva
Hi Siva,
Thanks for that! That fixed the problem.
I'll remember that one in future!
Cheers,
Dom.
