header modify per-request messes up virtual resources
telmosilva1
Hi all,
If there is anyone out there thant can help me with this issue it would be greatly appreciated.
One ACE Load balancer, balancing HTTPS traffic to a few servers.  Need to insert a x-forward-for on every packet.
To my limited knowledge, this can be done by either enabling header modify per-request or persistance-rebalance.
My issue is if I enable either one of those two, some files are not sent to the client.  These files re not actual physical files on the web servers but rather pointers to resources that interpret it.  Specifically:
<script src="/GlobalJs" type="text/javascript"></script>
This GlobalJs is not a file but rather a handler that represents a collection of bundled JS files.
1) Is there any way other way to ensure that the X-FORWARD-FOR is inserted each and every time
2) If header modify per-request or persistance-rebalance is the only way then why does ti behave different or have issues with the above <script>?
Thanks in advance
Here is my configuration:
parameter-map type http HTTP_PARAMS
  persistence-rebalance
parameter-map type ssl SSL_PARAMS
  session-cache timeout 300
  queue-delay timeout 1
ssl-proxy service SSL_CLIENT
  ssl advanced-options SSL_PARAMS
ssl-proxy service SSL_SERVER
  key key.pem
  cert cert.pem
class-map type management match-all PUBLIC_REMOTE
  2 match protocol ssh source-address 109.190.124.40 255.255.255.255
class-map type management match-all REMOTE_ACCESS
  2 match protocol ssh any
class-map match-all VIP-HTTP
  2 match virtual-address 37.59.87.65 tcp eq www
class-map match-all VIP-HTTPS
  2 match virtual-address 37.59.87.65 tcp eq https
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
  class REMOTE_ACCESS
    permit
policy-map type management first-match REMOTE_PUBLIC_MGMT_ALLOW_POLICY
  class PUBLIC_REMOTE
    permit
policy-map type loadbalance http first-match HTTP_L7_POLICY
  class class-default
    serverfarm SERVERFARM_REDIRECT_HTTP
policy-map type loadbalance first-match SSL_BACK
  class class-default
    serverfarm SERVERFARM_APP
    insert-http x-forward header-value "%is"
    ssl-proxy client SSL_CLIENT
policy-map type loadbalance https first-match HTTPS_L7_POLICY
  class class-default
policy-map multi-match WEB_TO_VIP
  class VIP-HTTPS
    loadbalance vip inservice
    loadbalance policy SSL_BACK
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 3091
    appl-parameter http advanced-options HTTP_PARAMS
    ssl-proxy server SSL_SERVER
  class VIP-HTTP
    loadbalance policy HTTP_L7_POLICY
interface vlan 500
  no shutdown
interface vlan 750
  no shutdown
interface vlan 1269
  ip address 37.59.87.75 255.255.255.240
  alias 37.59.87.73 255.255.255.240
  peer ip address 37.59.87.74 255.255.255.240
  access-group input ANY
  service-policy input REMOTE_PUBLIC_MGMT_ALLOW_POLICY
  service-policy input WEB_TO_VIP
  no shutdown
interface vlan 3091
  ip address 172.31.255.251 255.240.0.0
  alias 172.31.255.249 255.240.0.0
  peer ip address 172.31.255.250 255.240.0.0
  nat-pool 1 172.31.255.248 172.31.255.248 netmask 255.240.0.0 pat
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  no shutdown
Kanwaljeet Singh
Hi Telmo,
You are right that for ACE to look at each and every http request you need to use either persistence rebalance or header modify per request  but please note that persistence rebalance will also make the ACE to loadbalance every http request and if requirement is to just modify (insert, rewrite, delete) then header modify per request is the best option or you need to use sticky if you are using persistence rebalance. So in your case you should use "header modify per request".
Now coming to your problem i have no idea what does the above script do. But ACE should not remove or modify anything unless it is told to do so. So if you are seeing that applying the above parameters makes the ACE to remove that script from forwarding it to the server then that is a problem. I would suggest opening a TAC case for further investigation. But your configuration looks good. Remove persistence rebalance though.
Kanwal
Hi Kanwal,
Thanks for the response and for confirming the difference and the use of header insert and persistance balance.
I have found the issue to be the content lenth in fact.  The GlobalJS was indeed a file that was larger than other items on the page and by adding:
  no persistence-rebalance
  set header-maxparse-length 8196
  set content-maxparse-length 8196
  length-exceed continue
It now works.  I am about to remove the header-maxparse as I dont see why the header on this would be larger than others.
Thanks!
Telmo
Hi Telmo,
Sounds good.
Kanwal
