help about WAAS SSL optimized policy
chia hao chang
hi everyone
I enable SSL optimized function and it work fine
but I have a question
in my environment, most SSL tcp session size is under 10 KB
so when small size tcp session optimized by waas
it's optimized bytes is bigger than original byte
so, does waas have the function that if  the tcp session original size under 10KB
it only opimize in TFO or pass-through it
on the contrary, if tcp session original size is bigger than10KB
it will full optimzed
does waas has this function ??
thanks
9 Replies 9
Zach Seils
Level 7
Level 7
WAAS does not have the function you describe.
Can you provide the sh stat conn detail statistics from one of these connections?
Zach
HI~ zach
thanks for ur response
an appendix file is I show stat con detail server-port 443 information
thanks
Notice the highlighted line in the output you provided:
Core-WAE#sh stat con detail server-port 443
Connection Id:            852083
    Peer Id:                  00:14:5e:85:26:c3
    Connection Type:          EXTERNAL SERVER
    Start Time:               Tue Jun  8 09:29:29 2010
    Source IP Address:        2.2.2.2
    Source Port Number:       2930
    Destination IP Address:   1.1.1.1
    Destination Port Number:  443
    Application Name:         SSL
    Classifier Name:          HTTPS
    Map Name:                 basic
    Directed Mode:            FALSE
    Preposition Flow:         FALSE
    Policy Details:
           Configured:        TCP_OPTIMIZE + DRE + LZ
              Derived:        TCP_OPTIMIZE + DRE + LZ
                 Peer:        TCP_OPTIMIZE + DRE + LZ
           Negotiated:        TCP_OPTIMIZE + DRE + LZ
              Applied:        TCP_OPTIMIZE + DRE + LZ
    Accelerator Details:      None
                                    Original            Optimized
    Bytes Read:                       958333              1431050
    Bytes Written:                   1137856              1198434
    Total Reduction Ratio: 00.000%
This means that the SSL AO is not applied to this connection.  Are you sure this server is configured for SSL acceleration?  Can you please provide a copy of your configuration?
Zach
Zach,
I also have Accelerator Details:      None
But in the CM I have "Full Optimization" under Connections Statistics
Jan
Can you please provide a copy of your configuration (WAAS devices on both sides of the link)?
Zach
chia hao chang
I enable SSL in my LAB environment that's ok
and I can see SSL icon in device monitor connection statistics
but in user site, i cannot see the SSL icon
I think that's why Zach said no SSL policy apply to SSL connection
all device configuration are configure from AllDeviceGroup
my https web site ip address is 192.168.3.88:443
my configuration sequence is
1. open cms secure-store
2. create a cipher
3. create a SSL Accelerated service name "mega-www" and add my HTTPS web ip address 192.168.3.88 port 443, then import the web certificate and private key
4.my application is SSL and classifier is HTTPS, I add my web ip address 192.168.3.88 port 443 into HTTPS classifier
   application is full optimization and position is first
but it is stange, cause in my lab environment, it's ok, but in user site, it's not work
an appendix file is my core-wae and branch-wae show run config
is this issue related with web CA ?
thanks
Do the Disk Encryption needs to be enable on all WAE to get the SSL to work?
If found this error.
WAAS03#show statistics accelerator ssl | inc Failed
   Total Failed Handshakes:                                           39086
   Total Failed Certificate Verifications:                            0
   Failed certificate verifications due to invalid certificates:      0
   Failed Certificate Verifications based on OCSP Check:              0
   Failed Certificate Verifications (non OCSP):                       0
   Total Failed Certificate Verifications due to Other Errors:        0
   Total Failed OCSP Requests:                                        0
   Total Failed OCSP Requests due to Other Errors:                    0
   Total Failed OCSP Requests due to Connection Errors:               0
   Total Failed OCSP Requests due to Connection Timeouts:             0
   Total Failed OCSP Requests due to Insufficient Resources:          0
Jan
it's needn't because my ssl opimization work fine in my lab environment without enable disk encryption
but why it is not work in user site
i'm waiting for Zach responce^^
Where are the client and server located relative to the configurations you provided?
Zach
