Help with NM-CE-BP configuration
wupchurc
Hi, I'd like to do some caching of web pages using the NM-CE-BP for clients that are local to the module. I'm have problems getting the module to "talk" with a C3750 switch using WCCP v2. Can someone provide me with some simple configs fo the Switch and the NM-CE-BP module to provide web caching of HTTP traffic destined for port 8080?
Zach Seils
Level 7
Level 7
Wray,
The following configuration should work:
NM-CE:
wccp r 1 x.x.x.x
wccp custom-web-cache r 1 port 8080
wccp v 2
IOS:
ip wccp 98
interface
ip wccp 98 red in
Zach
Zach,
Thanks for the help.
As a follow on, is there a way to verify caching on the NM-CE?
what would it look like on a 3750 instead of a router?
The IOS commands on the 3750 would be the same as a software-based platform. There are some additional restrictions on the 3750, such as only supporting L2 forwarding (l2-redirect), mask assignment (mask-assign), and inbound redirection.
Zach
