Help with Replacement of Localdirector
david.morrow
Hi all. I am hoping to draw on the wealth of Cisco product knowledge in this forum to help me actually chose a product.
I currently have several Cisco Localdirectors deployed. Cisco has discontinued the product. I am currently preparing to implement a new application which will require load balancing. I require no more features than what Localdirector provided. Can anyone recommend a Cisco product which provides basic server load balancing similar to that which LD provided?
Gilles Dufour
I would go for CSS11501.
If you need SSL or more performance, the 11503 or 11506.
If you have Cat6k already in your network, you can have a look at the CSM or CSM-S
Gilles.
Thanks for the response. I guess I will need to look into the CSS11500 product.
carlsond
If you don't need anything advanced there are server laod balancing features built into IOS. All you need is an existing router.
