Hi everyone. I'm trying to use SSH for router and switch
pierre512
I'm trying to do that in cisco paket racer
in switch i have vlan 10 and vlan 20 and in the router port0/0 i used no ip add then i used encapsulation dot1q to share the port with this tow vlan i have.
i did the SSH in the router and in the switch in vlan1 but now i can go in into the router with a pc who is connected to vlan 10 or 20 but i can't connect the switch
have anyone an answer for why i can't connect the switch with SSH
because the switch has a different IP address and belongs to VLAN 1
On Router, try add below config
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.0.0.1 255.255.255.0
no shutdown
On SWITCH :
ip default-gateway 10.0.0.1
Try Ping from router to 10.0.0.15  - Ping ok ?
Try ping from switch to 10.0.0.1 - Ping ok ?
Add RSA Keys for SSH :
######### Generate SSH keys :
ip domain-name bb.com  (change what ever you like)
crypto key generate rsa  ( use 1024 or higher for security)
Then test from Device to connect to switch.
BB
balaji.bandi
From Vlan 10 and 20 are you able to ping Router IP ?
can you post switch side and router relevant config to look ?
BB
Yes i can pin router from vlan 10 and vlan 20
this is the router config
Current configuration : 1297 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
enable secret xxx
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.2.1
ip dhcp pool vlan10
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip dhcp pool vlan20
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip cef
no ipv6 cef
username R1 secret xxx
ip domain-name R1.se
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.2.1 255.255.255.0
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
and this is the switch one
Current configuration : 809 bytes
version 12.1
hostname S1
enable secret xxx
ip domain-name S1.se
username S1 secret xxx
spanning-tree mode pvst
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet1/1
switchport access vlan 10
switchport mode access
interface FastEthernet2/1
switchport access vlan 20
interface FastEthernet3/1
interface FastEthernet4/1
interface FastEthernet5/1
interface Vlan1
ip address 10.0.0.15 255.255.255.0
line con 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
no shutdown
On SWITCH :
BB
