How to build a SSH Probe
stephan.sieger
can anybody give me an example of a ssh probe for a 6066 CSM?
Tia,
Stephan
Gilles Dufour
you can't do any encryption on the CSM.
So you won't be able to simulate a real SSH connection.
Can you sniff a connection and see what data is being sent....
You can then make a script to resend the same data and stop before encryption starts.
See other TCL probes as an example.
Checl the SSL probe. This is basically what you have to do.
Gilles.
