How to bypass some source address in Transparent Caching with CSM ???
drazik
Hi.
If configuring bridge mode or routed mod in Transparent Caching, need some source IP bypassing and the other source IP caching.
Is it possible? if possible, let me know how to configuring.
thank.
Gilles Dufour
You can create a newvserver for those clients that need to bypass caching.
This vserver will be identical to existing cache vserver except that you will use a different serverfarm [ie: a farm with predictor forward] and you will also add the command client to define which client can hit this vserver.
Gilles.
