How to check DNAC SSL Certificate in CLI
MohanKumar30269
Hello All,
How to check the DNAC SSL Certificate expiry date via CLI Command?
Mohan Kumar
7 Replies 7
balaji.bandi
Thank you for your reply, Balaji. I'm looking for a CLI Command to view the certificate details so that we can automate using the NetBrain tool to run this command every month and send us the report to track of the expiry date.
Cisco point of view CLI OLD fashion, better look API.
BB
alisha_rascon01
To check the expiration date of the SSL certificate on a Cisco DNA Center (DNAC) appliance using the Command Line Interface (CLI), you can follow these steps:
1. Access the DNAC appliance via SSH or console cable.
2. Log in to the DNAC CLI with appropriate credentials.
3. Once you're logged in, you can use the following command to check the SSL certificate expiration date:
show crypto pki certificates <certificate-name>
Replace <certificate-name> with the actual name of the certificate you want to check. If you're not sure of the certificate name, you can use the following command to list all certificates:
Look for the certificate entry that corresponds to the DNAC's SSL certificate and note the "Valid from" and "Valid until" dates. The "Valid until" date is the certificate's expiration date.
Here's an example of what the output might look like:
Certificate
Status: Available
Certificate Serial Number: <serial-number>
Certificate Usage: General Purpose
Issuer: CN=Example CA
Subject: CN=dnac.example.com
Valid from: <start-date>
Valid until: <expiry-date>
Fingerprint: <fingerprint>
In the example above, you would be interested in the "Valid until" date, which indicates when the SSL certificate will expire.
Keep in mind that you may need administrative privileges to access this information, and it's essential to regularly check and renew SSL certificates before they expire to ensure secure communication with your DNAC appliance.
rehmatbibi791
To check the SSL certificate expiry date for Cisco DNA Center (DNAC) via CLI, use the command "show platform software security certificate detail." This command provides detailed information about the SSL certificate, including its validity and expiry date. Look for the "Valid From" and "Valid To" fields in the output to determine the certificate's start and expiry dates, allowing you to monitor and ensure the certificate's validity and a renewal as needed.
Thanks for your reply, but it says unknown command! Do I have any other mode available? It looks like taking very limited commands and those are Linux-based.
[cid:image001.png@01DA0DAE.F21FECA0]
@rehmatbibi791 are spammers, responses are bot-generated and are not necessarily correct.
