how to configure bypass for ssh to web server in another side of CSS11506
julxu
Greeting,
I tried to configure to allow system administrator use ssh to access WEB server.
I did:
acl 1
clause 20 bypass tcp nql UWS eq 22 destination nql local-WEB-Farm
apply circuit-(VLAN1)
But, I still do not understand how the outside can ssh into web server? there is no route for the privite network in another side of CSS?
Is that means I need configure a routing protocol to let outside see the server?
Any comments will be appreciated
Thanks in advance
Julie
Gilles Dufour
Julie,
why do you need a bypass acl ??
Bypass is usually needed when the destination ip/port could match a content rule and you don't want some hosts to hit the rule but instead simply forward the traffic ?
Do you have a content rule matching any traffic ??
This type of acl is usually being used for HTTP in a caching environment, so I really don't see why it would be required for SSH.
Regarding your next question, about how to reach the subnet behind the CSS, simply use common routing principles.
Think of the CSS as a router.
If you want to reach a segment attached to the CSS, you need to make sure the rest of your network knows about it.
I would not recommend using routing protocols on the CSS itself.
Instead, I would configure a static route on a next-hop device and propagate the route from there.
Gilles.
Thanks for rating.
