Using PERMEO with the SSL module?
sgonsalv
Level 3
Level 3
Has anyone had any success in trying to use a PERMEO client on their desktops, and having it do the handshaking with the SSL module?
thanks
Sheldon
mchin345
Level 11
Level 11
I dont think that the PERMEO wil lwork with the SSL module. This is not supported with SSL and also is not compatible. You can try other vendor modules.
After a lot of testing, we've found the same result that it isn't compatible with the SSL module.
thanks
Sheldon
Sheldon,
the SSL VPN feature will exist in our VPN3000 concentrator and exist or should soon be out for the IOS.
I would suggest you to contact a Cisco Sales person.
He should be able to guide you to the right solution.
Gilles.
