how to connect pc and CDM4650 console port ?
iwan2u
i set windows hyperterminal (9600bps, data bit 8 , no parity, stop bit 1, flow control none)
and connect pc and CDM4650 console port with rollover rj45 cable. but there is no reponse.
what is correct method to connect pc and cdm4650 console port?
Not applicable
Try using a serial cable instead of the RJ45 connection. I had the same issues connecting with the included RJ45 to serial connector and a variety of cables.
