How to debug ACE FT Sync Problems ?
Fresenius-Netcare
Frequent Visitor
Frequent Visitor
in one of our contexts we have a sync problem on the standby unit.
"sh ft group detail" gives
"Running cfg sync status : Error on Standby device when applying configuration file replicated from active", while "Startup cfg sync status" is OK.
"sh crypto files" and "dir disk0:" produce the same output on both ACE units.
How can we analyze the problem ?
Gilles Dufour
Get a 'show ft history ha_mgr' and 'show ft history cfg' and 'show ft history ha_dp' after a failure.
The reason for the problem should be there.
Gilles.
Hi Gilles,
unfortunately I can not see a meaningful message. Can you please have a look at the attachments (taken from the standby machine) ?
Thank you very much in advance.
We need the same info from the standby.
Also do not forget the 'show ft history cfg' as it is most probably the one containing the error.
G.
