how to downgrade Cisco WAE and waas module software 5.2 to 4.3.3
asif.mo01
we are using Cisco Wide Area Application Services module in router, Waas software version is 5.2.1
we want to downgrade to 4.3.3
plz help us to how to downgrade 5.2.1 to 4.3.3
Router - CISCO2921/K9 and Waas Services module - SM-SRE-710-K9
6 Replies 6
finn.poulsen
Level 3
Level 3
WAAS version 4.3.x is NOT supported on SM-SRE-710-K9 !
You'll need version 4.4.x or later.
Version 4.3.x is supported on SM-SRE-700-K9 (the previous model).
Best regards
Finn
Thank for support
Hi Finn
Please help us once agian how to downgrade 5.2.1 to 4.4.x version
may be Version 4.4  is support on SM-SRE-710-K9
plz  - Help us how to downgrade 5.2.1 to 4.4.x version
Don't know whether you managed to do this, but otherwise :
My suggestion would be latest release in 4.4.x - which is 4.4.7a.
And another strong suggestion is to upgrade your central manager to that version as well (CM should always be the highest version among your WAAS farms).
Please read the release notes (both for 4.4.7 and 5.2) on upgrading and downgrading,
Otherwise it would be (from the WAAS SRE-710 module with network connectivity) :
copy ftp install <ipaddress of ftp server> <url path and imagename>
check this link :
http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/waas/v521/command/reference/cmdrbook/execmds.html#wp1043584
Best regards
Finn
Hi !
How  are u !
We are unable to ping WAE -7341 -k9  ip address!
i was check the cable and Reset also ! we are unable ping 1
We are getting system locator led indication on devices
regards
Asif
Hi Finn,
We need your help !
We have configuring  the WAE - SM-SRE-710-K9 Module on CISCO2921/K9 - Version 15.4(3)M1 .
Problem is we are unable to ping our SM-SRE 710 module ip 10.22.12.5 .
Please check below config.
EX : interface SM1/0
 description ***SM-SRE 710 ***
  ip address 10.22.12.1 255.255.255.0
  ip flow ingress
  service-module ip address 10.22.12.5 255.255.255.0
 service-module ip default-gateway 10.22.12.1
no keepalive
No sh
After configuration done Sh run con
interface SM1/0
ip flow ingress
service-module fail-open.
no keepalive
Asif
