10-29-2015 03:36 AM
we are using Cisco Wide Area Application Services module in router, Waas software version is 5.2.1
we want to downgrade to 4.3.3
plz help us to how to downgrade 5.2.1 to 4.3.3
Router - CISCO2921/K9 and Waas Services module - SM-SRE-710-K9
10-30-2015 03:03 AM
WAAS version 4.3.x is NOT supported on SM-SRE-710-K9 !
You'll need version 4.4.x or later.
Version 4.3.x is supported on SM-SRE-700-K9 (the previous model).
Best regards
Finn
11-02-2015 01:32 AM
Thank for support
11-05-2015 04:29 AM
Hi Finn
Please help us once agian how to downgrade 5.2.1 to 4.4.x version
may be Version 4.4 is support on SM-SRE-710-K9
plz - Help us how to downgrade 5.2.1 to 4.4.x version
11-10-2015 02:25 AM
Don't know whether you managed to do this, but otherwise :
My suggestion would be latest release in 4.4.x - which is 4.4.7a.
And another strong suggestion is to upgrade your central manager to that version as well (CM should always be the highest version among your WAAS farms).
Please read the release notes (both for 4.4.7 and 5.2) on upgrading and downgrading,
Otherwise it would be (from the WAAS SRE-710 module with network connectivity) :
copy ftp install <ipaddress of ftp server> <url path and imagename>
check this link :
http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/waas/v521/command/reference/cmdrbook/execmds.html#wp1043584
Best regards
Finn
04-05-2016 09:07 AM
Hi !
How are u !
We are unable to ping WAE -7341 -k9 ip address!
i was check the cable and Reset also ! we are unable ping 1
We are getting system locator led indication on devices
regards
Asif
06-12-2016 11:35 PM
Hi Finn,
We need your help !
We have configuring the WAE - SM-SRE-710-K9 Module on CISCO2921/K9 - Version 15.4(3)M1 .
Problem is we are unable to ping our SM-SRE 710 module ip 10.22.12.5 .
Please check below config.
EX : interface SM1/0
description ***SM-SRE 710 ***
ip address 10.22.12.1 255.255.255.0
ip flow ingress
service-module ip address 10.22.12.5 255.255.255.0
service-module ip default-gateway 10.22.12.1
no keepalive
No sh
After configuration done Sh run con
interface SM1/0
ip flow ingress
service-module fail-open.
no keepalive
Asif
