How to fix Fault Tolerance on ACE 20?
netternewbie
I have two ACE 20's in two 6500's. I have an Admin context with a number of contexts. Unfortunately one context has the backup as FSM_FT_STATE_STANDBY_COLD not Standby_Hot.
I have checked its configuration and noticed a number of lines missing from the correct active context. I know now I have to force the config across by taking the ft-group out of service.
My question is do I do this on the working ACE or do it on both ACE's admin groups?
I think this is what I do.
config ft group X
no inservice
Give it a few mins to sync across to broken ACE and then put it back inservice?
Or do I need to do this on the broken ACE? I don't want to lose the good config and the broken config to copy across.
32 Replies 32
It went into cold state straight away. I went on active and did no ft-auto sync runn and then ft-auto sync runn. Unfortunately still getting the sticky error but a shorter one than last one.
sh ft config-error
Wed Jun  4 14:50:48 UTC 2014
`sticky ip-netmask 255.255.255.255 address source STICKY-SSL-****-FARM`
Error: sticky resource not available
`serverfarm ****-FARM`
Error(s) while applying config.
I have removed the stickyfarm and put in a test probe and it works fine. Very minute i put in sticky farm it breaks. How do you mean remove sticky group?
Hi Kanwalsi,
Just fixed it. resources not fully allocated on standby ace. Thanks for your help on this.
Hi Netter,
I thought you had already applied. But i am glad issue is resolved.
Kanwal
