How to insert X-Forward header in Cisco ACE
koustubhjoshi
We are using Cisco ACE 4710 to load balance servers. We have created VIP under the interface vlan using nat-pool command
Also, we have changed the gateway of the server to point to the ACE vlan ip address which is created using alias 10.x.x.x 255.x.x.x command under the interface vlan. In short ACE is in inline mode for the servers which needs to be load balanced.
Load balancing works fine, but the issue is in the access.log of the server, we see the VIP not the original public ip.
the class-map & policy-map configuration is as follow.
class-map match-all CLASS_VIP
  2 match virtual-address 10.1.X.X any
policy-map type loadbalance http first-match LOAD_BALANCE_POLICY
  class class-default
    serverfarm SERVERS_FARM
policy-map multi-match POLICY_VIP
  class CLASS_VIP
    loadbalance vip inservice
    loadbalance policy LOAD_BALANCE_POLICY
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 510
I have tried to insert following
  class class-default
  insert-http x-forward header-value "%is"
But still I am not able to view the original client IP. Just to add more, the site is a HTTPS site & we have not doing any kind of SSL offloading on the ACE, it is taken care by server itself
I just want to do the HTTP & HTTPS load balancing without SSL offloading & should be able to see the original client IP in the server logs
can anybody help here.
Thanking everyone in advance.
Kanwaljeet Singh
If SSL offloading is not happening then ACE cannot insert X-forwarded-for. ACE should be able to look into HTTP header to do the same but since it cannot due to no SSL offloading happening it will not work. If this is HTTP connection then above should work just fine.
So either you can do SSL offloading on ACE or you cannot insert X-forwarded-for. Again for HTTP it should work fine.
Kanwal
