How to properly shutdown ce510
y.lo
Seems that it's running Linux and I don't find any shutdown or halt command. I assume I shouldn't simply press the power button. Can anyone help?
didyap
Level 6
Level 6
I am not sure if there is a procedure to shutdown the CE. However you could use the Reset button provided in the panel or power it down.
