How to set trap destination on GSS
georg.tresselt
Can anyone tell a poor fool like me how to enable SNMP traps and set the trap destionation on a GSS ? Can't find it in the documentation.
Thanx alot
Georg
Gilles Dufour
there is no snmptrap support on the GSS currently.
You will have to use syslog.
Moe.GSS1.com(config)#logging host ?
enable Enable remote logging
ip IP address of host
priority Priority level when log to host
subsystem Set subsystem level logging severity
Gilles.
- please take the time to rate each answer provided to you by our community.
Well, that's not exactly what I'd like to hear. Thanx alot anyway
Given that the GSS actually runs Redhat Linus with a UCD-SNMP agent, isn't there a work-around like setting the trap destination directly in a config file?
unfortunately there is no workaround.
Several customers requested the snmp traps and it is apparently on the roadmap.
If you really need this feature you should ask your Cisco sales representative to contact the GSS product manager.
Gilles.
