How to Virtual IP configuration in ACE module?
rachitdholakia
I am in the process of configuring load balancing on ACE module but struggling to configure virtual IP address for ACE module.
I'm working on ACE30 module and using software version A5 (1.2). ACE module is in slot of Catalyst 6504 switch.
Can anybody please post the steps/commands to perform this activity? An early response would be appreciated.
Rachit.
5 Replies 5
Cesar Roque
Level 4
Level 4
Hi Rachit,
Here is a basic configuration example:
access-list Allow_Access line 10 extended permit ip any any
rserver host test
  ip address 10.198.16.98
  inservice
rserver host test2
  ip address 10.198.16.93
  inservice
serverfarm host test
  rserver test 80
    inservice
  rserver test2 80
    inservice
sticky http-cookie test group2
  cookie insert
  serverfarm test
class-map match-all VIP
  2 match virtual-address 10.198.16.122 tcp eq www
  policy-map type loadbalance first-match test
  class class-default
    sticky-serverfarm group1
policy-map multi-match clients
  class VIP
    loadbalance vip inservice
    loadbalance policy test
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 112
interface vlan 112
  ip address 10.198.16.91 255.255.255.192
  access-group input Allow_Access
  nat-pool 1 10.198.16.122 10.198.16.122 netmask 255.255.255.192 pat
  service-policy input NSS_MGMT
  service-policy input clients
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.198.16.65
Here is the configuration guide:
http://tools.cisco.com/squish/101AD
Cesar R
--------------------- Cesar R ANS Team
Hi Cesar,
Many thanks for your reply.
I did the configuration and it is working (may be parially) now. I still have few questions so if you can help please.
1) I did not have aby Virtual IP configured for ACE30 module on which i am working on. Is following command responsible for creating/configuring Virtual IP address for ACE module?
If not, what this command exactly does?
2) I have configured round robin predictor for my configuration that contains 4 rservers, each with equal weight value. The configuration is for http loadbalancing. What i was expecting is that when i open browser 4 times, every time it will go to new server. But, instead of that, it follows random pattern like it goes to one server couple of times and then goes to another server and so on. Also, if i just refresh in the same browser, it stays on the same server. Is it expected behavior? Is it something which need to do in my http cookie settings or some other setting in my browser which opens http connections?
Rachit.
Hi Rachit,
About your first question, this is the line that define the VIP address:
This line is for natting purpose, it could be to NAT the source address of the clients:
About your second question, yes the behavior you mentioned is normal.  If you refresh the page in the same browser the client will go to the same server because is using the same session.
Cesar R
Hi Cesar,
Thanks.
Is NAT really mandatory for this configuration to work?
I removed "nat-pool 1 10.198.16.122 10.198.16.122 netmask 255.255.255.192 pat" configuration from interface and removed "nat dynamic 1 vlan 112" from policy-map but then loadbalancing configuration didn't work.
Rachit.
Hi Rachit,
Is not mandatory because there are other ways to make it work.  The problem basically is that if you don't use the nat, the servers can see the real client IP address, so when the server sends the response back if there is a L3 device between the ACE and the servers it will try to send the traffic directly to the client bypassing the ACE. Meaning an assymetric flow.
When you use the nat the source IP address will be the nat-pool, so the server will send the response back to the ACE and then the ACE will send it back to the client.
There are other topologies where the nat is not needed like Route Mode or One-Armed mode where there is only a L2 devices between the ACE and the servers, that way the traffic has to come back to the ACE because is the only path
Cesar R
