HTTP-Cookie Stickiness is not working on ACE 4710.
Amjad Hashim
Hi ALL,
I have configured a service with a VIP listening on 443, at the minute both servers at the backend are using self signed certificates but eventually SSL will be terminated on ACE.
My requirement is to configure sticky sessions using http-cookie, i have configured it but ACE is not working as expected.
The user logs into the server and while browsing they get kicked to the second server and are prompted to login page again.
is it because the ACE can't extract the cookie from encrypted text or it is something else.
My config is very simple, please find it below.
serverfarm host SSDSD_SF
  probe SSDSD-ServerAvailability-443
  rserver SSDSD-AL2 443
    conn-limit max 4000000 min 4000000
    inservice
  rserver SSDSD-AL3 443
    inservice
sticky http-cookie JSESSIONID SSDSD_Sticky_SF2
  replicate sticky
  serverfarm SSDSD_SF
lass-map match-all SSDSD_443_WEB
  2 match virtual-address 10.xx.xx.xx tcp eq https
policy-map type loadbalance first-match SSDSD_443_WEB-l7slb
  class class-default
    sticky-serverfarm SSDSD_Sticky_SF2
class SSDSD_443_WEB
    loadbalance vip inservice
    loadbalance policy SSDSD_443_WEB-l7slb
    loadbalance vip icmp-reply active
Kanwaljeet Singh
Hi Amjad,
You are correct. ACE has no way to look into HTTP header since it is encrypted. For ACE to do HTTP based stickyness, you should terminate SSL on ACE or as temporary workaround use source based sticky.
Hope this helps!
Kanwal
Hello Kanwaljeet,
Thanks once again for your prompt reply, what will happen if i terminate the SSL on ACE and the backend servers are also listening on 443??
Will the ACE be able to decrypt the data and extract the cookie out of it or will it go through the ACE and the real server will deal with it.
Amjad Hashim.
Hi Amjad,
In that case you will need to do END-TO-END SSL and ACE would be able to decrypt traffic and take decision on the basis of information contained in HTTP header. You can have more details regarding End to End ssl in below link.
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c6f37.shtml
Please let me know if you have any questions.
Kanwal
