HTTP Head Keepalive and IIS 6.0
plearmouth
The document
"Making Cisco CSS 11000 HTTP Keepalives and ColdFusion Servers Work Together"
implies that the CSS requires a response '200 OK' and a content-length header as well for a persistent connection.
It would appear that IIS 6.0 simply does a connection:close as some sort primitive method of suggesting the length, that is NO content-length header.
Either way the service keepalives stay down. I have not tried non-persistent connections.
I also found a bug fix that suggests that a 200 OK with no headers is sufficient for a KA.
The customer has 11506's so is the document still valid ?
Thanks in advance
Paul
Gilles Dufour
Paul,
With the method HEAD, the server is not supposed to return any data, just the header.
So if the header does not contain a 'content-length' the client/CSS has no way to know what is the data length.
Anyway, normally the CSS only check the response code. Are you certain the server returns 200ok ?
what's your software version ?
I think there was also another bug related to server closing the connection having a negative effect on keepalive.
I would suggest to try the latest version first and if the problem persist open a TAC case.
Gilles.
Giles
Thanks for your quick reply.
Below is a ethereal trace of the response (with a browser initiated GET to the URI in question).
This is all I have at the moment but it shows that for the GET ( HEAD should be the same) there is no
Ethernet II, Src: 00:0f:23:ec:1e:00, Dst: 00:0f:1f:71:a7:cf
Internet Protocol, Src Addr: 10.58.32.60 (10.58.32.60), Dst Addr: 10.60.32.84 (10.60.32.84)
Transmission Control Protocol, Src Port: 81 (81), Dst Port: 8196 (8196), Seq: 1, Ack: 545, Len: 239
Hypertext Transfer Protocol
HTTP/1.1 200 OK\r\n
Response Code: 200
Connection: close\r\n
Date: Thu, 30 Jun 2005 09:53:35 GMT\r\n
Server: Microsoft-IIS/6.0\r\n
Content-Type: text/html; charset=utf-8\r\n
Expires: 0\r\n
Pragma: no-cache\r\n
Cache-Control: no-store\r\n
Set-cookie: ~http_content_charset=utf-8\r\n
\r\n
So is it required ?
Paul
As I said, the CSS normally does not need the content-length.
That's why I asked you about the version you are running.
Also, I would capture a sniffer trace of CSS keepalive using HEAD which can have different result.
Gilles.
Giles,
Used Telnet to confirm your suspicions,the response from the HEAD method was 500. Confused how you make a website
respond with a successfull GET method but then a 500 for the HEAD, I thought the purpose of HEAD was too allow the browser to check the properies of the content without actually retrieving it.
So, using the script AP-KAL-HTTPCHECK ( search a web page to locate a substring). Is there a way to pass a parameter like 'R/3 Status OK' as one entitiy, the parser seems to want to treat it as three seperate pieces.
I have hardcoded into the script to make it work.
Thanks in advance
Paul
