https failures with wccp
joet8591
Level 2
Level 2
Running acns/wccp and some https sites are not working. If client uses CE as his proxy then site works. With wccp I have to deny the web site on the wccp ACL to get it to work. Is there info in the packet that breaks security when using wccp?
The ACL option is not scalable and I am wondering if there are options or commands on the ACNS/CEs to fix this?
Joe
s.jankowski
Level 8
Level 8
CE currently works with HTTPS in bypass mode and tunnel the request back to origin
